Question about GE Washing Machines
What part has gone bad on my ge front load washer?
After i select a cycle and hit start the washer will lock the door then automatically start draining although there is no standing water in the unit. the only thing it does is stay stuck in drain mode. it won't fill or agitate, just keeps trying to drain. Im thinking its the pressure/flood switch. Any thoughts on this matter? Your advise would be greatly appreciated!
  • GE Master
  • 5,323 Answers
I d look at the control board or timer
Posted on Feb 20, 2015
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Posted on May 28, 2009
SOURCE: My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
My GE washer keeps pausing itself
The most common problem i have seen is the door lock has failed,but it can also depend on what part of the cycle it is pausing on.The other more common problem is the main control panel has gone bad,
Check to make sure there are no obstructions that would cause the drain pump not to pump out water.
Feb 26, 2010 | GE WSXH208A Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE WBVH6240F
check the door lock it may have a bad connection will the door lock?
Jul 11, 2008 | GE WBVH6240F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
