Question about Tablets & eReaders
Were in settings do i go to set up my screen to rotate?
    Problem Solver:
  • 7 Answers
On the main screen in settings there is a lock icon on portrait or landscape. Unlock it.
Posted on Dec 13, 2014
Why won't the screen rotate?
It may be a setting specific to the device, or a hardware fault.
An example of a setting issue, using an HP Slate 7,
HP 7 HP Slate 7 Tablets Screen Does Not Rotate Android 4 1 Jelly Bean
I post on behalf of HP
Jul 07, 2015 | Tablets & eReaders
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
How go I rotate my tablet to vertical
1. Tap on the top right corner of the Home Screen to access the tablet > utilities.
2. Tap Settings > Screen.
3. Tap to deselect/select Auto-rotate screen.
Oct 19, 2014 | ASUS Eee Tablets & eReaders
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
How do i rotate screen on my tablet?
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
Aug 13, 2014 | Tablets & eReaders
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
Screen will not rotate
Some tablets will have a physical rotate lock switch. There is also a setting that locks the rotation. Settings > Display. Auto Screen Rotate.
Dec 08, 2013 | Samsung Galaxy Tab Tablet PC
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
May 18, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Screen Won't rotate
you need to change your screen resolution to rotate, make it so that it is taller rather tan wider
Dec 27, 2009 | IBM ThinkPad X41 Tablet PC
Tablets & eReaders Logo
52 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
