Question about Craftsman Garden
What year is my sears riding lawn mower
Nil
  • Craftsman Master
  • 2,478 Answers
Model please
Posted on Dec 13, 2014
  • 376 Answers
SOURCE: murray riding lawn mower
Nix on safety switch. If it was a safety switch, you would not hear a click when you turned the key to start.. There would be no power going to the solenoid. However, if your engine has the fuel shutoff solenoid beneath the carb bowl, it will make a faint click when you just turn the key to the 'on' position. Probably as thabrain says, a bad solenoid.
Posted on May 15, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
suzukiracing
  • 200 Answers
SOURCE: engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Where can I obtain a manual 4 a Craftsman Riding 42" Lawn Mower - Mdl.#944608760?
at the sears parts website. They usually have them for sale or as .pdf files. you will need to know the sears model number.
http://parts.sears.com/partsdirect/index.action
Aug 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a wiring diagram for sears model 917.272066 riding lawn mower
Should contact SearsPartsDirect.com,they have all the wirings on all their Craftsman lawn tractors. There is another way you might find a wiring diagram. Look in back of your Owner's Manual,i have found a wiring diagram & part numbers to include,the whole tractor is broken down in a diagram format. There are other lawn mower shop that should have a wiring diagram,i.e. AMCParts.com. Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Oct 27, 2012 | Sears Garden
How old is lawn mower model # 917-273481
my parents had a 917.255561. I would guess around 18 or 19 years.
May 20, 2012 | Garden
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Sear ltv 10 varidrive lawn tractor
OLDER SEARS TRACTOR WILL NOT SHUT OFF WITH KEY. STARTS FINE.. ANY IDEAS WHAT TO LOOK FOR?
Jul 23, 2010 | Sears Garden
Craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Jul 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears Riding Mower stops running when the blade is engaged
check the deadman sensor under or in the seat. if it don't "see" you on the seat then the mower will shut down. good luck and hope this helps
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
