Question about Refrigerators
How do i get ice maker plastic drawer back in when panel in front of ice maker won't move?
    Top Expert:
  • Refrigerators Master
  • 36,394 Answers
I checked a similar ice maker and the panel is removable.
Posted on Dec 13, 2014
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
Ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
May 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker doesnt stop making ice
Check with an identical unit to see how that one moves. Yours may be dislocated. The lever arm probably contacts small plastic parts in the timer that could be out of place. Ice makers aren't too tough to take out and check out in a more comfortable work location. Just put a towel to catch screws.
Apr 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
