What causes the TV to go black and then when I touch the back it comes back on
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Loose wire or a short in a wire. Open back of TV and proceed with caution and observe the area in witch your concern may be and check for loose wires or wires that maybe split or broken also check ground wires and make sure they are tight be carefull not to ground any wires as this can damage or completely destroy your component..
Posted on Dec 13, 2014
My Sceptre TV changes source by it self and now every button I press changes the source.
It's most likely the remote. Try opening the remote (I know it's hard, and could be hard to put back together). The underside of the rubber buttons will need to be cleaned with rubbing alcohol and a Q- tip. You will notice some of the black carbon rub off onto the Q-tip (That's Okay). Then dip the Q-tip in alcohol and run it over the gold or silver areas that the rubber buttons touch to change the channels (and all the other places they touch too)Then wipe all those areas dry with another Q-tip, until no more carbon black comes off, and there is no moisture in the button side of the board. It was probably caused by an oil leak from one or more of the buttons. then reassemble OR try a cheap universal remote.
May 05, 2017 | Sceptre Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Tv will not come on. on and off button does not work/
Buddy the main cause of this types of problem can be shot circuit. if it is so then you have to go for service.
If your tv is working but power button doesn't work then you can unscrew it and have a look. see whether button touch the sensor(it is in black color). it doesn't touch then you have to make it enable to touch by add some layer of paper or plastic,,(tips. don't ever use metal object). ; )
Oct 09, 2010 | Vizio L37 Television
I have a rca 32v343t atc010a and when i turn it on the power light comes on and the tv makes a noise like its coming on but then theres no picture or sound. I would like to finde out whats causing this to...
It sounds like the High voltage transformer has gone out. If you open the back of the tv and look on the right side, you will see a large (4 - 5 inch) black cylinder with a large wire coming out of the top. without touching anything, look and see if it is cracked.
Feb 18, 2009 | RCA Televison & Video
Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
D52w23 rca makes an awful loud high pitched whine
This is a coil, now a NOISY coil.. It is a common problem, and happens often. The whine is caused by current passing thru the copper windings and making them vibrate! A commonly accepted repair for this situation is to squirt some regular old super glue into the copper windings and let it harden for a few minutes..Viola! no more whine!
Jan 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Curtis mathes tv - model cm25020s
had the same problem if you have any skills with soldering open it up and check on the pins on the thing in the back lefthand corner. On mine the solder has a circular crack around one of the pins that when the back was on on it pushed the chip itself up and cause that one pin to not touch. The thing i refer to is the black tower that has 2 philip type "screw" that you turn to change the defalt color or somthing like it. well hope what i said help if you have not trashed it or got a new tv... or both.
Oct 13, 2008 | Televison & Video
I have a panasonic tv. Last night it made a popping sound (like when there is a black out) but when I tried to turn the tv back on the screen remained balck and it made a hissing sound. Has the tv...
you have either a bad flyback, bad HV splitter or a Bad HV lead. Can you remove the rear panel and try to see where the hissing is coming from without touching anything? Then let me know, as those type of repairs are easy but you cant touch any parts while trying to determine where the sound is coming from
Aug 15, 2008 | Televison & Video
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
