Question about Samsung Tablets & eReaders
On my Samsung Table Galaxy 3, I tried one answer, but under settings, I don't find the Data Connections, except the VPN not APN and the tablet shows the VPN is locked, what can I do
I tried going to settings which I found the category "more settings" I that's where it leads me to VPN and I can't change anything there even when I hit the menu tab at the bottom of the tablet
My tablet will not turn off. It keeps restarting but will not get past the iRola screen.
About 15,600,000 results (0.52 seconds) Search Results
    The tab is in an endless reboot loop. - Samsung Galaxy Tab ...
    https://www.ifixit.com/.../The+tab+is+in+an+endless+reboot+loop.
    iFixitMy samsung galaxy tab 2 7.0 is turning on and off continuously. ... The second iteration of Samsung Galaxy Tab tablet computers with a 7.0 inch screen. .... to lose all the data, but still it does not lose and keep restarting over and over again.
    it keeps switching itself off - Samsung Galaxy Tab 3 10.1 - iFixit
    https://www.ifixit.com/Answers/View/.../it+keeps+switching+itself+o...
    iFixitMy Samsung galaxy tab 3 charges badly and keeps turning off and not coming ....What you will need to do is take the tablet apart, (carefully) and secure the battery to..... It shuts itself off and I have noticed that upon restart the Wifi is turned off.
    How to fix any Samsung Phone/Tablet that keeps rebooting ...
    ? 3:03
    https://www.youtube.com/watch?v=A-0LgvM-WNs
    May 30, 2014 - Uploaded by lennonSystems
    How to fix any Samsung Phone/Tablet that keeps rebooting(Boot Loop). lennonSystems ... with the s3 it does not work. trow it in the trash can ... When my phone does this I just let it do its thing, after a while it would stop.
Feb 09, 2016 | Tablets & eReaders
Does resetting my tablet to the factory settings get rid of everything
Hi
The answer is not quite everything, but it will return it to the same state as it was when you opened the box for the first time.
In other words you will lose all your personal settings, pictures, data, WiFi connections, Bluetooth pairings, downloaded apps, etc etc. Everything that you have done on it since you started using it.
It will be exactly as it left the factory
Cheers
Nov 17, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
3g dongle support
Hi
Seems like it needs to be configured, though not all tablets support dongles i.e Karbonn-Samsung Galaxy and lenovoA1000 & A30
First, (1) put 3G sim into dongle and connect dongle to tablet. You may have to wait several minuets for tablet to find internet, if it does not, continue as below.
2. Now go to 'settings' and select the 'More' option .
3. Select 'Mobile Networks' > 'Access Point' Name (APN) 4. Then select New APN option.
5. All you have to do now is make the following changes in the bracketed entities [ Name, APN and Dial Number]:-
-> Set the network name. Eg:- For Tata photon just write Tata or TP or anything, as you like it.
-> Set the APN,> search the net for your service provider's APN. Then write it precisely.
-> All the dongles come with dial number. Check your dongle purchase paper or the manual or just search it Google. And then fill the same here as the Dial Number, save and you are done. eg. For Tata Docomo it is #999 and Reliance it is #777.
NOTE:
After plugging the dongle, a default APN gets created in the APN setting's page.Try to feed the settings by creating a new APN.
Karbonn, Samsung Galaxy and Lenovo A1000 & A3000 tablet does not support dongle.
By far and large the above steps will work with all the dongles and Tablets. You could also go to 'You Tube' and seach for Video info which may be quite helpful. Regards Silverfox160
Ssssss
Aa
You can aaa
aa
a
Aug 27, 2014 | Irulu 7 Inch Android 4.1 Jelly Bean...
Can't sign into ebay
save all the data you need... then go to settings and choose restore factory settings... this case happens when the operating software wasn`t properly installed
Apr 03, 2014 | Samsung Galaxy Tab Tablet PC
My Samsung tablet 2 10.1 froze and i tried restarting it but its still frozen... what do i do?
Lost your files on Android phone & need to recover deleted videos,audios,photos? try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted videos. videos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted videos before recovery. Watch the video tutorial to learn how to retrieve videos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve videos lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Dec 31, 2013 | Samsung Galaxy Tab 101 Tablet...
Samsung tablet 7.0 will not turn on
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
Sep 13, 2012 | Samsung Galaxy Tab Tablet PC
I just bought a samsung galaxy tablet and i do not know how to set up the web cam on it. I also have skype installed on my tablet and for some reason i am not seeing a video call button when i click on my...
Hi! First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger. Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ). *This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work! Have a nice day!
Sep 02, 2011 | Samsung Galaxy Tab Tablet PC
Samsung tablet isn't connecting to 3g network but will connect to WiFi
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
Mar 20, 2011 | Samsung Tablets & eReaders
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Won't connect to 3g or wifi
Enable data connectivity on settings. To activate 3G, you must add a valid access point (APN)
Mar 01, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
44 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
