I need instructions on how to program Feature Comfort Ceramic Heater Model number HC - 0104s heater. Do not know how to operate and control
I need instruction manual of operation of this heater unit
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
I need a remote and filter for HCH6150
Here is a link to your heater manual.
Here is also one for Holmes Customer Support.
Sites holmes products Site
Holmes HCH6150 Product Manual
Oct 24, 2015 | Holmes HCH6150-U Triple Ceramic Heater...
Need manual for the comfort zone cz20110
NEED TO FIND OUT THE COMPLAINT DEPARTMENT, HEATER MELTED OUTLET AND PLUG NEED TO KNOW WHOOM TO CONTACT
Jan 07, 2012 | Comfort Zone CZ1500WC Infra-Red...
I have set the times for the heating to come on and put it to auto but it doesnt seem to come on at the times i've set it at??
If the Procom Model number you referenced is correct, this heater does not have a automatic timing feature to turn the heater On and Off. However, it does have a built-in thermostat control, that turns the heater's burner on, once the room/area drops below the temperature/comfort level you have set it for.
Conversely, it turns the burner Off once it reaches and holds the temperature/comfort level for 5 minutes or more, it turns the burner OFF, again. Keep in mind, because this is a built-in thermostat, it's reading the air temperature closest to the heater.
If the thermostat feature is what you're having a problem with, it may be that the sensor bulb has failed (assuming it's not turning ON & OFF automatically). However, this is a fairly rare failure. Unless, the heater is very old or hasn't been cleaned and serviced annually.
Another situation would be that the Control Knob has been left in the PILOT position, rather then the ON position. If that is the case, the heater will not turn ON, period.
Right now, your Owners Manual is your best source of information on the correct operation of the heater, as well as it's Trouble Shooting Guide.
If you have misplaced the Owners Manual, here's a printable link to it. Just locate the Model Number of your heater, ML300TB and click on the icon to the left of it.
http://www.usaprocom.com/manuals.php
Hope this helps you solve your problem.
Mar 03, 2011 | Procom ML300TBA Heater
Cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
Dec 05, 2009 | Honeywell HZ-338 Ceramic Compact Heater
I get lightheaded from the smell/fumes put out by this heater.
if this making you unwell a non ceramic should help , do you get headaches does it feel like you are getting the flu ?
Jan 17, 2009 | Comfort Zone CZ-441 Ceramic Heater
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
Oct 19, 2008 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
484 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
