Question about HTC Cell Phones
My HTC First is stuck on safe mode and when I try to reboot it the power button or volume down button doesn't work but the volume up button works fine and at the top its say "*** LOCKED***". How do
I've tried to call them and they said I need an account with them so I tried powering it off and turning it back o and that didn't work. I've tried holding down the volume down button and power down button that didn't work and I did the same with the top volume button and it got me into the phone but its still in safe mode and it wont put your apps that you download on there.
  • HTC Master
  • 928 Answers
To get out of safe mode all you have to do is reboot the device, nothing else. The phone should be bale to work fine but without any third party applications.
If what you see on the display is just a bunch of letters, then you are in the recovery section. I'm not sure, but I think that once you highlight a line just tap the Home icon to activate. Make sure that "Reboot Device" is highlighted to reboot the phone in normal mode.
Posted on Dec 13, 2014
How to reset my tablet royqueen no volume key?
From a prior Fixya volunteer answer:
1. Press the power button to get the option menu for
Power / Reboot / Silence option.
2. From that menu you'll have to hold down the Power button while holding down the Home button on the side of your tablet.
3. This brings up a menu to "Reboot Into Safe Mode" (These first 3 steps the manufacture fails to mention, which is where many users get stuck)
4. Hit yes for Safe Mode and then hold down both Power and Home buttons on side till the Dopo logo appears.
5. Release the buttons and hit the Power button one more time, then hold the Home button down till a menu option appears.
6. Use the Home button to move down to "Factory Reset" and press the Power button to select that option. Once it says "complete" then use the Power button to select "Reboot."
Sep 12, 2017 | Cell Phones
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
Dec 14, 2015 | Samsung Galaxy S6 Edge
How do I get my nextbook tablet out of safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Nov 04, 2015 | Nextbook Tablets & eReaders
How to get my android phone off of safe mode
Have you tried resetting the phone? That usually fixed the problem.
Jan 13, 2015 | Android Cell Phones
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Jul 16, 2014 | HTC One SV
How do you rest a thunderbolt
First, try this:
From the main home screen, tap menu
Tap Settings, then Privacy
Tap Factory data reset
Tap Reset phone
Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
Turn the power off. If your HTC ThunderBolt is frozen, pull the battery out and reinsert it
Hold the Volume Down button
Press and hold the Power button until the device turns on
You are now presented with a menu that allows for Fastboot, Recovery, Clear Storage, and Simlock
Select Clear Storage by pressing the Volume Down button
Press and release the Power button
Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC ThunderBolt. Once the wipe is complete, the phone will reboot to its factory fresh state.
Sep 06, 2012 | HTC Thunderbolt (8 GB) Smartphone
Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 29, 2012 | HTC Inspire 4G Smartphone
My HTC inspire is stuck in safe mode none of my apps show doesn't let me do many things help !
Apr 09, 2012 | HTC Cell Phones
Htc sensation stuck safe mode
This happened to me on HTC Sensation. I was able to get into my apps after a few attempts to reboot seems when volume is all the way down during a reboot it initiates the safe mode. this can happen, im told for many, reasons. Even if your volume controls are working fine.dust etc. although I followed the directions listed above I cleared the htc sense cache then re*stareted and all loaded just fine. I just had too do a little rearanging to my apps on home page . so I am pleased I saved a service call
Mar 27, 2012 | HTC Cell Phones
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
Cell Phones Logo
89 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
