Question about Tablets & eReaders
Chromo tablet.. My Chromo tablet is not showing all it features such as widgets were I can customize my tablet I can't add anything cause it only has one screen.
I can not connect wirelessly
I have had this problem before and I had to go under WiFi settings and forget my WiFi. I let it scan again for service and reentered my WiFi network information. This worked for me most of the time. However, it could be your WiFi itself. Can you connect anything else to your WiFi?
May 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
Can I put a 16 gb SD card into my chromo noria tablet that has 2 gb?
according to the write-up, you should be able to put anything up to a 64G card in it.
Here's a copy of the write-up for you. Chromo Noria Slimx 7 9
May 04, 2015 | Noria Tablets & eReaders
I could not turn on my the wifi on my chromo tablet
When you selected forget it erases the SSID and password you entered to connect initially so you will have to re- enter the info to reconnect!
Feb 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
Dec 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
Chromo tablet
Hi
Look for a small pin hole in the side or back of the case. Use a thin piece of stiff wire(paper clip, eye end of sewing needle) push it gently into the pin to press the reset button. Hope this hdlps. Regards Bob from OZ.
Jul 28, 2014 | chromo MID 7 Android 4.1 Tablet - Light...
Chromo tablet
You can't put letters on the number pad but you can change your password to be made up of letters. You do this by going to settings, security, then at the top of the page it will say number pad or something, you click on that, then follow the instructions.
Jul 20, 2014 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
I have a Chromo 7" tablet, IOS wont start up.
have you tried to press the reset button in back of your tablet.
Jun 26, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
Tablets & eReaders Logo
65 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
