Question about Insignia Solutions NS-SB212 Home Theater Soundbar
How do I reduce frequency response of NS-SB212 by a few db?
Thought of adding a capacitor/resistor on input lines
  • Bob Kalsey
    Bob Kalsey Dec 13, 2014
    Tnx. Freq 150Hz to 15kHz. need to reduce bass.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Insignia Sol... Master
  • 924 Answers
First off, reduce what part of the frequency response, and why? You would need to reduce it by about 3db to make a difference, and that may bleed over into other frequencies as well. What is the spec for frequency in your owner's manual currently? Yes, you can add an R/C filter, but you may have to play with the values to get it just right. I'm going to take a stab, and say you have to decrease the low end? I can tell you how to proceed an easier way. Do you have a schematic?
Posted on Dec 12, 2014
  • Bob Kalsey
    Don't have schm - looking for one - unit 150Hz - 15kHz. - need to reduce bass
  • Audio Service Clinic Dec 14, 2014
    So at 150htz, it's still to boomy? I will need to know exactly what kind of input cable you are using.
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Jan 02, 2015 | Insignia Solutions Original INSIGNIA TV...
How do you set the switches on AT3525 Mike?
The AT3525 handles very high sound pressure
levels with ease, accepting as high as
146 dB SPL before producing 1% T.H.D. A
switchable 10 dB (nominal) pad is built-in,
increasing its capabilities to 156 dB SPL.
An integral 80 Hz hi-pass filter provides easy
switching from a flat frequency response to a
low-end roll-off. The hi-pass position reduces
the microphone's sensitivity to popping in
close vocal use. It also reduces the pickup of
low-frequency ambient noise (such as traffic,
air-handling systems, etc.), room reverberation
and mechanically-coupled vibrations.
Jun 20, 2014 | Audio Technica Audio Players & Recorders
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
    this is actually the product description for your speaker
    Product Description
    Front
    Speaker Unit: 1inch +6.5inch *2+8inch
    Power: 10-100W
    Sensitivity: 88 dB
    Impedance: 4 ohm
    Frequency Response: 45-20K Hz
    Production Size: (H*W*D) 1087*210*336mm
    Package Size: (H*W*D) 1162*500*400mm
    CENTRE
    Speaker Unit: 1inch +4inch *2
    Power: 10-60W
    Sensitivity: 86 dB
    Impedance: 8 ohm
    Frequency Response: 75-20K Hz
    Production Size: (H*W*D) 160*500*179mm
    SURROUND
    Power: 10-60W
    Sensitivity: 85dB
    Impedance: 8 ohm
    Production Size: (H*W*D) 225*160*158mm
    Package Size: (H*W*D) 550*273*415mm /3PCS
    ACTIVE SUBWOOFER
    Speaker Unit: 10inch
    Impedance: 8 ohm
    Crossover Point Control
    Handling Power: 120W
    Production Size: (H*W*D) 405*328*350mm
    Package Size: (H*W*D) 465*330*465mm
    Jun 24, 2010 | Juster SP-615 Computer Speakers
    I am trying to find the output power, watts?
    bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
    Jun 08, 2010 | Audio Players & Recorders
    Wattage
    I have the following specs for you
    Basically 150watts per channel using two channels , or 75watts using all four
    Here goes:
    • 4 Channel Mosfet Amplifier
    • Advanced Overload and Thermal Protection
    • Metal Film Capacitors/Resistors In Signal Path
    • Frequency Response +/-1dB, 20Hz to 20 kHZ
    • Signal to Noise Ratio (A-weighted) >100dB
    • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
    • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
    • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
    • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
    • Minimum Load when Bridged 2 Ohms
    • Minimum Load per Channel 1 Ohm
    • Input Signal Voltage Range 0.1 volts to 2 volts
    • Crossover Type Resisitor Network, Linkwitz Riley,
    • Highpass/Lowpass
    • Crossover Slope 24 dB per octave
    • Crossover Frequency Range 20-550Hz
    • Factory Crossover Setting 85 Hz
    • Auxilary Output Channels 2
    • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
    • Bass Boost 0- to +18dB @ 45 hZ
    • Power Supply Voltage 10Vdc to 15.5Vdc
    • Recommended Fuse 40 amp
    Dimensions 12.25L x 9.25W x 2.10H
    May 23, 2010 | Car Audio & Video
    Insignia Solutions NS-SB212 Home Theater Soundbar Logo
    69 people viewed this question
    Top Insignia Solutions Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Insignia Solutions Audio Player and Recorder Expert? Answer questions, earn points and help others
