Question about Toys
Hi we have brought this child's electric car and
Hi we have brought this child's electric car and after charging it did work but we tried it again and it won't turn on at all we think on of the wires may have come loose but are not sure do you know any where we could take it to be looked at or fixed please, we live in gillingham kent. Thanx
    Sergeant:
  • 153 Answers
HI please check if the car has a power supply safety switch.Test the battery to see if voltage maintains after charged. charger may be faulty. importantly be advised item may have a aftersales waranty.
Posted on Dec 12, 2014
  • 625 Answers
SOURCE: stereo wiring
test all gronds and powers then the remaining cables use a AA batterie and conect one cable on each end on the baterie like on of on of like toching at times and that will make the speakers to sound for a little then you will identify every speaker then read the diagram on the radio and plug it in acording to the radio diagram
Posted on Jun 01, 2008
  • 625 Answers
SOURCE: 1993 Ford Ranger charging system problems
in order to answer your question i need to know if you have internal or external regulator for alternator
Posted on Jun 02, 2008
  • 8 Answers
SOURCE: speedometer stops working
This most likely is a wiring issue. Since it works intermittently I suspect you have a wire that looses connection and then vibrates around enough to make a connection. I would have a ford mechanic to look at it. This is probably a problem that they have seen before verses a shop that you will pay a couple of hours locating the problem or them not finding it at all.
Posted on Dec 31, 2008
JShreader
  • 50 Answers
SOURCE: i'm looking for a wiring schematic for the
Hello freak4style, my name is JShreader. Thank you for choosing fixya.com.
Click HERE for the Wiring Diagram for the Fan Circuit on your Lumina. I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Posted on Apr 01, 2009
  • 12744 Answers
SOURCE: abs light comes on along with the track off light
first check the sensor wiring at the front wheels behind the rotors is a wire that runs into the hub and out to the abs control unit if the connection is not properly connected or the wire has a break it will erratically set off the abs sensor [check light ] which shuts down the abs module and u have normal brakes if wiring and connections are good have the vehicle scanned the van should have the problem code stored in the computer as a fault problem this will give u a start point most auto stores will scan a vehicle for free and give u the code and meaning such as auto zone / advanced auto check in ur area good luck
Posted on Jan 18, 2010
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
My Child Pad won't come on. My dad thinks it's something to do with the screen but I'm not so sure. Why won't it come on and how can I fix it?
I think I may be able to help you. So the same prob;e came with my childpad. Just remember as long as it does not work have the password with you. Because my works now but I forgot the password. So I opened the back blue thing. And then I figured that the charging thing was to loose. So, I just have to make it so that the charger won't come out, so some how my dad make it tighter. But I think that might be the problem with yours as well. If you have a solution to my problem (forgot password) please email me at hinazaheer1@gmaill.com Thanks!! And I hope it helped in some way :)
Mar 03, 2013 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
2003 avalanche ran out of gas left radio on bat went dead. Got new bat. But truck won't turn over on dash light came on with pic of truck with lock through it what is wrong. No clicking or anything...
No i think that where the battery ran flat it has brought the immobilisor on ,try the spare key and if that doesnt work call the dealer to have it reset again
Apr 13, 2012 | 2003 Chevrolet Avalanche
R530 switchesoff
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the battery dropsoff to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 12, 2012 | Samsung R530 Notebook
06 trailblazer trouble with anti theft system, I think, starts right up then other times the anti theft light comes on and it won't start. can try it 2-4 hours later and it starts right up????
The first thing to do get it checked for DTC'S - diagnostic trouble codes . Not at auto zone or any other parts store , you want to have full scan of all the modules on the car. Don't know how much you know about automotive electronics , computer controlled systems etc.... Your vehicle has at least 10 modules (computers ) on board , there all talk to each other on a serial data network . C.A.N - controller area network . Or in the case of GM it has it's own . GMLAN -
How to Diagnose Controller Area Network CAN When you turn that ignition switch to start it is an input to the computer ,be it the PCM or BCM ..
Jul 01, 2017 | 2004 Chevrolet TrailBlazer
The is a CL display on our dryer. What does it mean?
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again.
Hope this helps...
Daniel
Sep 02, 2010 | LG DLE2512W Electric Dryer
2004 Nissan Xterra. Three of the electric windows don't work.
Most likely master window switch in drivers door.
Jun 06, 2010 | 2004 Nissan XTerra
Hob not working
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Ethernet
The internet cable fed to your modem by your ISP if faulty.
Jun 29, 2008 | Computers & Internet
Toys Logo
785 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
