Question about Apple iPhone 4S
Won't hold a charge
Dead in about 2 hours, have had new battery put in,port checked and apps closed
    Problem Solver:
  • 11 Answers
I have found that there is low quality battery's sold on ebay and some service providers also install cheap battery's. That a side.
there is a free battery replacement from apple check out on the apple site to see if your phone qualifies.
I bet the person that suggested microwave also wanted a iphone but was sucked in by a smooth taking sales person and now is stuck with it.
Posted on Dec 13, 2014
    Problem Solver:
  • 5 Answers
Put it in the microwave for about thirty minutes and then go by an android phone
won't hold a charge - /uploads/images/hold-charge-34767802-4-1.jpg
Posted on Dec 12, 2014
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
What can se do about a Kindle HDX 8.9 that only has a battery life of 20 minutes.
Put it in airplane mode and charge, turn off to charge, close all windows and apps. Try new charger, clean port and plug with alcohol. If none of those work check warranty
Sep 19, 2014 | Amazon Kindle Fire HDX 8.9
Virginmobileusa com activate
it is yr port take it in get it looked at
Jul 15, 2013 | Cell Phones
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Battery won't hold charge - fine for 4 hours or so then dead
need to check battery and charging system with tester sounds like possibility of a bad charging system, alt or voltage regulater or bad connections
Feb 18, 2009 | 1992 BMW 5 Series
Battery will no longer hold charge
Get a new battery.
Just like on my cell phone, if I go a long time with it, it goes dead faster, for example the first day I got it would last at least a couple days, now it lasts maybe 10 hours, or so.
Buy a new battery.
Oct 21, 2007 | Samsung YH-925GS MP3 Player
Dead battery for one unit won't charge at all. voltage -0- both radios and charger work fine. where can I get battery? P/N MN-160001 capacity 950mAh
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Sep 13, 2007 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Apple iPhone 4S Logo
64 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
