I am trying to connect a lg sound bar to a blaupunkt TV. But it doesn't have a digital optical connection. Can I still connect it and how? Thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
If you have a digital coax out, or vice versa, they make digital optical convertors. Try MCM Electronics.
Posted on Dec 12, 2014
4 Suggested Answers
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need.  Set the output on the source unit to optical out.   Connect the optical cable to the amp.  Connect the speakers to amp.  turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
Posted on Feb 11, 2009
bshldn
  • 736 Answers
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Posted on Jan 27, 2011
sethtorvea
  • 17 Answers
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
Posted on May 08, 2014
Just purchased Rico bos90. Put optical cable from my lg tv to the optical on the sound bar. No sound whatsoever
You may need to configure either the TV settings or the sound bar to use the optical connection. If both have HDMI connections, you might consider that connection method as an alternative.
Aug 03, 2016 | LG Televison & Video
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
I am trying to connect a LG sound bar to my Blaupunkt 50" TV. I havent got a digital optical connection on the TV. How can I connect the soundbar?
There should be audio output with your TV. Connect it with the Sound bar; using an AV cable. The cable might have three cores to connect, but you need to connect its Red and White pins. Leave the Yellow pin free; as it is meant to connect to Video. Electro help
The connection cable will look like this.
Dec 12, 2014 | Televison & Video
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Where was my problem solution posted on this site?
I only see one previous post of yours at FixYa, about a password to some unspecified website.
If you posted your question on some other website then please go to that website to find solutions.
Jan 24, 2014 | FixYa Service
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
