Question about KitchenAid KDRP407H Dual Fuel (Electric and Gas) Kitchen Range
Went to turn off oven...hit reset button and the control panel sent dead inc the over lite. Gas cooktop continues to work. I've check current it and its OK
Checked current which is OK
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
Http://www.manualslib.com/k/kdrp407h.html
call asistance. electricall troubles
Posted on Feb 25, 2015
SOURCE: constant beep
http://www.applianceblog.com/mainforums/showthread.php?t=3537
Posted on Mar 15, 2008
aborcass
  • 2651 Answers
SOURCE: My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Posted on Nov 30, 2008
Treefrog15
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
aborcass
  • 2651 Answers
SOURCE: KithchenAid Range KERS807SSS000 Problem--just like the Nov 30th one.
welll although oyour not running self clean, its possible you have a bad fuse. youll need to pull unit out and get behind to check the fuse for continutity, its a small (quarter sized thermostat) wioth 2 wired leading in and out of it, should have asticker with blue& white stripes on it.heres the part number if needed 9759242
Posted on Dec 30, 2008
SOURCE: Oven went dead in self clean mode and the door
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Posted on Mar 30, 2010
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
Meat does not brown in gas oven
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Oct 28, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
Where is the fuse in under-counter miccrowave?
remove the vent grill at the top, may have to slide to left after screws are removed. then you will see a screw holding the control panel, remove. then slide the panel up slightly and the panel should come off. behind the panel you fine a 20 amp 250 vac glass type fuse. remove and replace. if your MW works cool,,,,, if it does not you may need to call for service.
Jan 23, 2012 | Amana Microwave Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KDRP407H Dual Fuel (Electric and Gas) Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
