Set clock code - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
What is the brand name to your clock? Provide more details; please. http://electronicshelponline.blogspot.com/
Posted on Dec 13, 2014
Clock face does not show DST. When clock is set to correct time, it turns back one hour at midnight.
DST start and stop was changed a few years back. If you clock has embedded code with the old start and stop, the only way to fix it is to turn off automatic DST. Not sure what clock you are using however it appears to picking up the current GMT time. Another cause is if you have a time zone setting, CST, EST, PST etc.
Mar 20, 2016 | Audio Players & Recorders
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
What does this code mean
Its 5A6..... You have enter the oven into sabbath mode when try to set the clock. To exit sabbath mode press and hold the clock button for 10-15 seconds. When you set the clock yous press the clock button but dont hold it in.
Dec 09, 2015 | Cars & Trucks
Clock reset code ford focus 2000
There are many different clocks installed in vehicles depending upon the options listed. Check your owners manual for directions. One common error people make is trying to set the clock when it is on. It should be off when you use the set feature.
Jan 18, 2013 | 2000 Ford Focus
Need code to set clock acura 2000 tl
There is no code to set the clock. You use the H and M buttons
to set (H)ours (M)inutes. Just keep pressing button repeatedly until hour is correct, then
do the same for minutes.
Jan 30, 2011 | 2000 Acura TL
How do u set clock on deh p3000 pioneer
This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only when bluetooth adaptor is connected
Feb 24, 2010 | Pioneer DEH-P3000 CD Player
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
I need help setting the clock of my 2004 Acura TL
you need correct security code 1st
May 07, 2009 | 2004 Acura TL
How to set the time
Try this combination: Cancel, Clock, ### (time numbers), Clock again If that doesn't do it, contact Danby here: http://www.danby.com/page.asp?code=7
Sep 04, 2007 | Danby DMW1400 Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
