Question about Amana Refrigerators
Water chute in ice maker keeps freezing? - Amana Refrigerators
    Master:
  • Amana Master
  • 993 Answers
Note that doors of frige should be tightly closed, fan in freezer side should be on & running condition, donot put the items in freezer closely,there should be more gap within all items,adjust thermostat to lower position about half,then press autodefrost switch ,wait for auto restart about one to three hours
Posted on Dec 13, 2014
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
Kenmore Elite side by side - Icemaker chute freezes up, no ice
To make sure I am understanding you correctly, are you saying that after a normal fill, water continues to drip into the ice maker and freezes in the fill chute?? If yes, than replace the water valve.
If not then:
does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Kenmore where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Kenmore and inquire about the aforementioned. If this is your case, there is a good chance they will cover it.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
The water is freezing in the chute coming down to the ice maker from the water line before it can get into the ice slots. what could be causing that ????
Sometimes water molecules will gather there over time and eventually will bulid up. chances are you have a plastic chute and those tend to gather ice easy opposed to the rubber ones. Either way, if you pull the chute out from the back of the refrigerator and clear the ice out you'll be back in business.
Nov 08, 2010 | Refrigerators
The ice maker is working fine but ice cannot be dispensed because the chute keeps on freezing
The door to the chute is sticking slightly open allowing moisture in an freezing the chute and the door is then frozen open. You will have to disassemble the small door assembly, there has to be an obstruction holding this small door open.
Jan 03, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
44 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
