Toshiba32w1333db flashing green and red won't turn on any suggestions
Unplugged power and all service leads for long periods , tried to start without service leads,still won't power up?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
These red and green indicators generally flash in a certain sequence. Sounds like a power supply issue to me, but you would have to have the service manual to know for sure. These products are only troubleshot to the board level, so between the board($150-$200) plus labor, they are generaly not cost efficient to repair, Sorry.
Posted on Dec 12, 2014
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Green light on mittsubishi tv 65inch won't quit
It is the set's brain trying to boot up. (not unlike a computer) These sets if unplugged and power applied should blink 70 seconds and then go out and then can be turned on.
The model number will determine my answer/suggestions=
Models beginning with WD are nasty if this problem.
Models beginning with WS are not quite so nasty to deal with.
A full model number will tell which you have.
Mar 22, 2012 | Mitsubishi Televison & Video
Sony Bravia KDL-55EX500 flashing green and yellow light, an won't turn on. Any suggestions?
you guys are going to love me. lol. i figured it out at least for mine. $ )
1.start by unplugging the tv and everything plugged into it(make sure the only thing plugged into the tv is the power cord).
2. next plug in the usb flash drive with the update or a compatible version of the firmware.
3. now while holding down the up arrow button on the tv remote, plug in the tv and keep holding the up arrow while pressing and holding the power button on the side on the tv until you see the light on the tv go from solid green to solid red and yellow flashing lights. once you see this just sit back and wait a few min for it to force the update and it should turn on when its done.
let me know if this works for you as well or if you need any clarification. also know that step three is a pain to do alone and must be all done within a short period of time preferably at the same time.
Oct 16, 2011 | Sony Televison & Video
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Power flashes green then turns red; Lamp flashes red.
is this a flat screen first off
if it is 90% of the time the vid card has over heated they have a video card kinda like pc's one thing is most companies dont put fans on them so they over heat especially when dust start collecting on it wait and see if anyone else has any thoughts on this but im pretty sure thats it you will need to take it to someone that works on tvs to replace it and also ask them if they will install a fan on it
but like i said wait and see if anyone esle has any thoughts on this first
Apr 28, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
