Question about Frigidaire Freezers
My upright Frigidaire freezer stopped running. I have checked the outlet and it functions just fine. The light doesn't come on, no controls work makes no noises. Acts like there is no power to the unit, but outlet works
  • Official Brand Answer
  • 2,267 Answers
Hello Ed Greene, thank you for your inquiry!
I see that your Frigidaire freezer is not operating. You explained that the outlet is working and the lights or controls are non-operational. It sounds like a potential issue with the power cord or control panel within your freezer. It would be best to have a technician come out to the home to review the freezer to diagnosis the correct problem and replace parts as necessary. This will help avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Posted on Dec 16, 2014
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright FFU17f9gw3 temperture light is on and food is starting to thaw. I put alot of freezer jam in freezer yesterday
If the control is "ON" and the compressor is not running, you will need a start relay... Make sure you didn't accidentally turn it off by pushing food against the control knob!
Jun 06, 2016 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The light bulb in my My Frigidaire fkfh21f7hwa upright freezer started blinking and the fan would stop running whenever I open the door. The control panel would also beep and flash between 0 and 1. I
Hello Ricco, thanks for your post!
Based off the information you have provided it sounds like a possible issue with your control panel or power cord within your Frigidaire freezer. I would recommend performing a reset on your freezer and you can do that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue with the freezer I would recommend consulting with a professional technician for a proper diagnosis to be completed. Best of luck! -Matt
Jan 10, 2015 | Frigidaire Freezers
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
Freezer seems to be stuck in defrost mode
Sounds like the pat test fried the pcb. They use too high a voltage to test the appliance wiring and it doesn't do printed boards much good!
May 11, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezers Logo
159 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
