Http://postimg.org/image/hma4uc5bp/ Do you think this is the main board causing this problem? This is a plasma Sanyo P50HDTV10A
How to fix double image on sanyo lCD _40xr11fp
The T'Con board fault can cause a double image. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 07, 2016 | Sanyo Televison & Video
What is this part? http://postimg.org/image/cn92pu2c1/
H'mmm, I can't say that I recognize that part. It might be part of the middle or upper wash arm assembly, but I don't know for sure.
Mar 16, 2015 | Kenmore 15762 Dishwasher
Http://postimg.org/image/hma4uc5bp/ Plasma tv main board problem?
What is the problem you faces with your Plasma TV? Want to buy a new main board? If you wish to get a genuine replacement, contact the authorized service center of your TV brand. You can get it by online stores like Ebay, RS electronics and such; and can be purchased from local electronic spare part selling shops too. The number to the board is an important matter to note.
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 12, 2014 | Televison & Video
Should motor on AQ113F497I be earthed
YOU COULD HAVE A LOOSE WIRE IN THE RECEPTACLE IN THE WALL THAT THE WASHER IS PLUGGED INTO YOU MAY BE SMART TO HAVE AN ELECTRICIAN CHECK YOUR WALL PLUG OR AN EXPERIENCED HANDYMAN? THANKS JOHN
Apr 08, 2017 | Hotpoint Washing Machines
My facebook page
You can use the zoom in your browser :
In Google Chrome :
http://s13.postimg.org/7wl6jn3tz/google_chrome.png
In IE :
http://s13.postimg.org/j53yl671j/image.png
In Opera :
http://s13.postimg.org/y2cfm6k9z/Opera.png
Dec 02, 2013 | Facebook Social Network
Multiple vertical white lines
hi,
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrlbt-xl-eax35683901-ebr35855501/
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrrbt-xr-6870qsc107a-6871qrh073a/
If you need any more assistance feel free to contact me through fixya.
Ajin
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines on my vizio p50hdtv10a
If its one large line an inch or two you have a problem with the x boards. If its several thin lines multiple its going to be in your digital/main board.
Nov 21, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio p50hdtv10a left third of screen is black on all inputs. I still see pixel flicker at start up so I don't think the display is damaged. Out of warranty and of course Vizio is no help.
Check the connections on your Y sustainer board (the board on the left that go vertically if facing back of unit). Also check the driver boards toward the bottom of the TV. Your connection may not be in all the way and that will cause the missing display.
May 31, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sanyo plasma 42 TV Turn off for no reason
Ok Fellas I found the Problem!
The Problem is the V4 Y-Main Board. This board is located on the left side of the case looking upright from the back. I spoke with may suppliers, and Sanyo all confirming this. Apparently it has been an issue for some time. Sanyo has replaced the V4 Y Main board with a W1 Y main board in newer models. The W1 Board is NOT compatible for us tho. Just to be sure... If your T.V is taken apart (like mine) Disconnect the peripheral cable from the V4 Y Main, and turn on the set. I bet it will power up with audio and channel function just NO picture. When you plug the board back in... POOF set shuts down. Replacement boards are VERY hard to come by. So Happy Hunting!
42' HD V4 Y-MAIN
PCB: LJ41-02760A LJ41-02761A LG92-01200A BN96-03352A
Oh yeah.. just FYI, Sanyo, Phillips, and Samsung all use the same parts. Hopefully that will help your searching.
Aug 26, 2007 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
