My PORTABLE. DVD MAKES NOISES PHILLIP - Televison & Video
  • 757 Answers
There are 2 possible causes. Either the bearings for the spindle motor, or the tracking mechanism for the laser. It depends on when you're hearing the noise. If the noise is heard continuously then the spindle motor bearings may simply be dirty. If this device has hinged lid to allow the loading of your discs; then open it and remove any loaded disc. In the middle is where the spindle motor is mounted, and the locking mechanism that holds them into place. One small drop of lightweight household oil such as what you'd use to lubricate an electric shaving device would be all it takes right into the spindle top where you press with your finger to unlock your loaded discs. Put in a drop and spin it with your finger.
Next, look into open space of the chassis where the laser is mounted. Use a cotton swab or small brush to remove any dust or grime from way screw and guide shafts. Look at the plastic gears for broken teeth. There will be ribbon style electric cable connector; make sure that a loop of it isn't sticking up into the area of the disc tray...if it is, carefully reposition it.
Posted on Dec 13, 2014
5 Suggested Answers
jaffa012001
  • 376 Answers
SOURCE: Hi i need to find
1. Open the DVD cover
2. Press setup
3. Type 9 6 5 3
4. Press the Arrow Key up or down and select 0 for region free
5. Hit OK
Posted on Aug 29, 2008
  • 644 Answers
SOURCE: phillips portable dvd player will not play dvds.
Your best bet is to contact the manufacturer or shop you bought the item, as it is still under garantee they should be able to repair or issue a replacment for the faulty one, it is pointless trying to get it repaired if the item is under warranty as opening it up or getting an idependant repair done on the item will void any warranty. hope this helps.
Posted on Sep 20, 2010
  • 3 Answers
SOURCE: grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Posted on Jun 09, 2012
app_3rp85790
  • 16 Answers
SOURCE: i need a manual for my phillips dvd portable player model 702/37
This is the manual is available and FREE at this site...they also have a couple other manuals on spec..etc
I hope this helps you!
http://tv.manualsonline.com/manuals/mfg/philips/pet7402d05.html?idRes=15898868
Posted on Jun 22, 2012
I need a manual for my phillips dvd portable player model 702/37
Jun 22, 2012 | Philips Televison & Video
Grinding noise whle movie plays on portable dvd player
Jun 09, 2012 | Philips Televison & Video
Phillips portable dvd player will not play dvds. Phillips dvd player is still under warranty.
Sep 20, 2010 | Coby TF-DVD7380 Portable DVD Player
Dvd wont play
Maybe the laser is broken. You should send it back for repair.
is it an original dvd?
Apr 22, 2010 | Philips PET702 Portable DVD Player
Lost powercord
Go to www.sears.com the parts dept have make and model ready!
Thank you for useing us!
Dec 13, 2008 | TruTech PVS12701 Portable DVD Player
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips Televison & Video
Phillips Portable DVD player 8.5"
Unfortunatly the " Phillips Portable DVD player 8.5" does not have expandable batterys to buy...... but i do have a tip,to make your dvd player last a bit longer " turn the backlight off,to do this go to settings" this will help!
thanks,and have a nice day!
Sep 13, 2008 | Philips DCP855/37 Portable DVD Player
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
