Question about Frigidaire Refrigerators
The Fresh food light and the display lights went out at the same time.
New fresh food light bulb and door switch
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, Gearld Beebe!
I understand that the light inside of your Frigidaire refrigerator and the display lights are no longer working. It sounds like you could be having a faulty wiring issue or power issue. You may want to have a technician come out to review your refrigerator to assure each component is getting the proper amount of energy or have a electrician come out to review the receptacle to assure it is providing accurate energy. I hope this information is helpful. -Matt
Posted on Dec 16, 2014
Testimonial: "I replaced the dispenser circuit board. It all works now."
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Posted on Oct 28, 2006
SOURCE: light
I have a Whirlpool side-by-side refrigerator. The freezer is too cold, ice cream get has ard as rock, but the fridge side is very warm, althought i turn it to to the coldest setting. Food is getting bad very fast. Does someone know how to fix it?
Thanks.
Posted on Aug 02, 2008
  • 13 Answers
SOURCE: problems with fresh food side
go to nearest supply house or a good hardware store buy a themometer in the domestic ref, temp range. then compare it to read out.question is you house at 77 degrees. no way will domestic side have such an instant change in reading, the walls of the ref keep a long time fix on temp change.trust the themometer.
Posted on May 03, 2009
SOURCE: fresh food section lights work intermittantly.
I had the same thing happen to my LG LFX25950SB French door style. It is out of warranty but when I called 1-800-243-0000 LG customer service, they were very helpful. The CSR instructed me to take the lightbulbs out and he scheduled a service tech out within 5 days. No charge for parts or labor. I must admit I am impressed.
Posted on Feb 02, 2011
How To enter programing mode The W10312695 Control Board
Open the fresh food door and hold the fresh food light switch closed while pressing the freezer temperature down key three times in a row. This must be done within 10 seconds.
Release the door switch.
The control will display PE to confirm entry into programming mode.
You need to confirm entry into programming mode by pressing the freezer down key once more.
The control should display zero on both led's.
Set the control to the correct code as shown on the model and serial number sticker in the fresh food section.
This is done by pressing the fresh food up and freezer up buttons until the correct code is displayed.
Once the desired program code is displayed, press the freezer down key until the program code begins flashing.
Once the programming code has been saved the programming mode can be exited by closing the fresh food door.
Sep 11, 2014 | Whirlpool Refrigerators
No power and no light in the fresh food compartment
Start with a light switch. Might need a new board too.
Jul 25, 2012 | Frigidaire Refrigerators
Light does not come on when you open door
Test your 40 watt light bulb in another fixture if the light bulb is OK then unplug the refrigerator and open fresh food compartment and pry out the light switch. Test for continuity HERE For some reason your model shows an additional light switch on the control panel located inside the fresh food compartment above top shelf. Try switching the ligh switch on from there. Here is a Photo Click HERE Here is a replacement light switch=> Light-Switch-2149705-00557365 If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light wont shut off, heats up to 88 degrees
Most times this is a defective fresh food section door light switch located in this photo as location number 609. Click Here=> PSC23NSTESS Fresh Food Section I am going to send you the service manual for your model and the information that explains how to change the switch is on page 19. If you do not already have the new free Adoobe Reader installed on your computer click here=> Adobe Reader X (10.1) Just make sure to uncheck the items not needed during the download. There also could be another problem related to the mother board that can also keep the light on while door is close but not likely. The part number for the light swirch is=> WR23X10175 Light Switch Information on how to test the switch is also on that page. Until we have repaired the problem please unplug and remove the lights because this heat will keep the refrigerator running and possibly melt the plastic housing holding the bulbs. Click here for the=> GE Artica/Profile Service Manual
Here is another page with information and wiring diagrams=> GE Artica/Profile Technical Information
I will be here to assist you if you have any questions so feel free to let me know, Thanks Sea Breeze
Please rate this solution and as always Thank You for using Fixya!
Jun 21, 2011 | GE CustomStyle PSC23NSTSS Stainless Steel...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Light will not work, ice maker will not work
OK, we need to know what door, freezer or fresh food section? Tell me that and I will trace it through the wiring diagram.Please confirm your model number? GD2SHGX Could be only the door switch. Sea Breeze
Apr 08, 2010 | Whirlpool GD2SHGX Refrigerator
Ess22xgmdww light wont turn off and fresh food is not cold
push the light switch in and see if light goes out,if not change the light switch,if it goes out check to see if door has dropped down,sometime the door cam or hindge problem drops the door down and can't hit the light switch to shut it off,i've seen 40 watt light bulbs deform the plastic on the door and the floor of the fridge so take out the bulb for now,
Nov 01, 2009 | GE Refrigerators
Freezer not working
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
Adaptive defrost control
Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Heater / Thermostat
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 01, 2008 | Frigidaire FRS26R4A Side by Side...
Problems with fresh food side
Jun 09, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Fresh food compartment not cold, light is lit when door closed
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
