Question about Acer Computers & Internet
My desktop rebooted have a P215H acer monitor the words acer came up now only black screen and flashing blue light at on and off wsitch is there an easy fix
Disconnecting monitor completely and reconnecting, rebooted modem and computer and now just flashing light and black screen can hear computer loading
SOURCE: Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Posted on Jan 12, 2008
SOURCE: Monitor problem
i have the same problem , so after the p.c. is turned on and gone through it;s startup procedure, i wiggle my mouse and press the last button to my right on my monitor , and there you go, hope this helps?
Posted on Jun 09, 2008
SOURCE: No Signal when desktop wants to load
This is exactly what is happening to my monitor but happens a bit faster. Once the drive starts then the monitor turns on and turns straight back off again. The monitor works on other people's computers (including the tech guy at the shop I bought it from, making me look like a fool). However, once it has run on someone else's computer, it works fine on this one until it has had a long shut down (overnight). I updated drivers yesterday. It can't be too high a resolution since this is the highest one I have used before and the monitor I have plugged into it now has a resolution of 1366 x 768 and it is handling it.
Posted on Jul 20, 2009
SOURCE: vs10162 monitor: when i switch on the computer the
I had the exact same problem I would check your refresh rate and your resolution settings once I fixed that the problem went away :D Hope this helps good luck :D
Posted on Jul 30, 2009
  • 235 Answers
SOURCE: I just purchased a new cpu and plugged in my Acer
have youre cpu check if the monitor works on other computer, then the problem is in your cpu, if you hear any beeping sound a bad memory or vga could be posible, try removing it clean it and put it back, also if you have a vga card install clean it also then reboot, also check the power supply if it is working properly
Posted on Nov 20, 2009
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 06, 2012 | Computers & Internet
Acer p215h desktop monitor will show windows xp logo than goes blank
Mostly because of the resolution,
1. startup press F8 >>>
2. select ENABLE VGA MODE
3. Adjust Resolution ( right klik on the middle of the screen > properties > go to the up right corner > settings ) Slide to the LESS Screen Resolution > apply > ok
4.Restart your PC
Aug 15, 2011 | Computers & Internet
I have just bought an acer aspire x3400, I followed all the installation instructions, turned it on and the monitor came on, displayed the word Acer, then a blue box popped up and said no signal and the...
Make sure the cable to the PC is secure by tightening the screws on each plug. If the problem still exists then you need to take it back to the shop where you bought it from. It could be a fault graphics card or connector.
May 28, 2011 | Acer Aspire X3400 PC Desktop
The screen is a little fuzzy and gets dimmer than when i first start the computer and some times flickers
I had the same issue with my P215H from Acer. I downloaded the drivers from the acer website and installed them. I also changed the refresh rate from 59 Hz to 60 Hz. My monitor is much clearer now.
Nov 16, 2010 | Acer X203H bd Monitor
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
