Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
How do I fix the volume on westinghouse tv? The volume is stuck on low and if I use the remote nothing happens.
The model number is W2613. I've tried unplugging the TV, tired the remote (from cable box and the original remote to the TV), and nothing happened. The volume menu is on the screen at 0 and it's just staying on the screen. The buttons on the TV itself don't work. The only thing that does work is the picture. I can't access the menu on the TV to try and fix it.
SOURCE: Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
Posted on Jul 31, 2007
  • 36 Answers
SOURCE: no power but ON button flashing
Quickest fix for this is probably to temporarily unplug the monitor power cord.
For your other outages, I assume the monitor is connected to a computer, make sure the operating system power-save features have not disabled the video output signal from the computer ... if so, monitor should re-activate when you use the mouse or hit a key on the keyboard.
If your computer has two video outputs, make sure the primary display hasn't been shifted to the other one ... try it by moving the LCD data cable to the other video connector on the computer.
Posted on Dec 26, 2008
localwonder
  • 6784 Answers
SOURCE: TV will not turn on
HI, this is a failed inverter board. this will need to be replaced in order to restore proper functions.
This failed board is responsible for distributing the power through out the set. it has failed.
Posted on Jun 18, 2009
SOURCE: Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Posted on Aug 05, 2009
  • 13 Answers
SOURCE: Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Posted on Jan 22, 2010
My Westinghouse TV was working just fine, but stopped turning on after I had issues with the cable box. Those are resolved, but I can't get it to turn on. Anyone have any ideas on how to fix this?
Patience may be the key--It may be substrate charge phenomenon--
Disconnect everything from the TV, including power cord and all ins & outs and wait awhile (3 days is sufficient) to let the internal charges bleed off. Reconnect TV and try it again. It sounds like a power surge (or lightning strike nearby) jammed a temporary "substrate charge" onto TV's circuitry.
May 05, 2015 | Westinghouse Televison & Video
We were given the TB110MW9 Digital TV DTV Converter Box for Analog TV but with no remote . we do have other remotes we've kept from our last box that also died.would we be able to use this re
I thought that model number looked familiar. The answer is a qualified yes. If you have a Magnavox or a Philips remote it should work. If you have a universal remote try to search for a code that will control the box.
Nov 29, 2012 | Magnavox TB110MW9 DTV Digital to Analog...
I 've lost the remote control for our toshiba super c3 tv, can I buy another Toshiba control ?
Try the toshiba site or Google the model number with "remote" to try to locate an original not a universal.....
Nov 05, 2012 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
My tv has no sound!
unplug from the wall for about 30 mins. plug back in and it should work. this was a trait with sets
Sep 06, 2009 | RCA F32649 32" TV
TV will not turn on
Jun 18, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
32" GE Stereo Monitor Guide+Gem Star Television
Pauz, we need the model number to be able to help you out, located on front of owners manual or on back panel of tv set. some of the GE/RCA built tv`s had problems with extra data bits from the satellite and it would kill the audio, yours may be one of those sets, heres the fix for them, shut off your tv, un-plug the tv`s AC cord from the wall outlet, wait 20 seconds, plug set back in, turn it on and see if audio has returned, you might get lucky :)
Let me know model number if unplugging does not re-set the audio, BMW Rider
Dec 10, 2007 | Televison & Video
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
128 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
