Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
Why is the power saver message flashing? its fully charged
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
It's because the designers thought you wouldn't trust that the battery saver function if it didn't flash or otherwise tell you it's working, I think it's directed toward the small child market.
why is the power saver message flashing?  its full - 25319214-bsuyhkhqafbapa0bd2i1nkk3-5-0.png
Posted on Dec 12, 2014
I have bought HANNSpad SN1AT7 Tablet ,it is full charged ,I've tried switching it on but alli get is the screen saver nothing else
Remove the battery cover and remove battery for about 30 seconds. Then replace battery and power up your tablet and see if that does not reset it.
Dec 09, 2013 | Hannspree HANNS pad SN10T1
Tip
How to Recalibrate a battery
SYMPTOMS- Short discharges and recharges do not fully synchronize the battery's fuel gauge with the battery's state-of-charge. This can result in the amount of power available in one cycle being less than expected or the battery meter being inaccurate.
Under normal usage, batteries should be calibrated a minimum of once every 3 months. Your battery can be calibrated by following these steps:
I - Disable the Windows Power Management
1. In Windows, right-click the Desktop and select Properties in the menu list.
2. Click the Screen Saver tab and then click the Power button.
3. Under Power schemes, select Always On in the drop down menu.
4. Under Settings for Always On power scheme, select Never in each of the drop down menus.
5. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
II - Fully charge the battery
1. Connect the AC adapter to the notebook.
2. Charge the battery until the Windows battery meter is at 100%.
III - Fully discharge the battery
1. Remove the AC adapter.
2. Keep the notebook on until the battery has completely drained and the notebook automatically turns off.
3. Connect the AC adapter to the notebook.
4. Keep the AC adapter connected to the notebook until the battery has completely charged.
IV - Enable the Windows Power Management
3. Under Power schemes, select Portable/Laptop in the drop down menu.
4. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
on May 11, 2010 | Computers & Internet
I have an LG-CG180. It is unlocked and all its features work fine. The problem is: when it gets idle, I mean after the screen lights and keyboard lights gets off, all the cellphone gets off. The...
If the battery charge level drops to low levels, the phone automatically activates Power Saver mode to conserve battery power until you can recharge it. You can set the phone to activate Power Saver mode at 10%, 30%, 50%, 70%, or Never. Touch Apps Key > Settings > Power Saver . The Power Saver mode icon is located in the Notifications panel. When the battery charge is low, a notification is displayed prompting you to turn on Power Saver.
Jan 15, 2018 | LG CG180 Cellular Phone
My kindle wi-fi is not working. I went to turn it on and the light came on but stayed at the screen saver screen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Sony PRS600 "do not disconnect"..slow to charge
The circle with a line through the Reader and the message that says "Do not disconnect" will appear on the Reader while it will be connected to the Computer. This is a normal operation. And the Reader requires to be connected at least 4 hours to get it fully charged. Please keep connecting the Reader at least 4 houtrs to get it fully charged.
Jan 05, 2010 | Sony Reader Touch PRS-600
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
My nokia phones battery backup is very less
Disable bluetooth if you are not using it- Disable screen saver (power saver always enabled)
- If you are listening MP3's and you don't expect phone calls, enable flight mode (if you have 6.65 firmware)
- FM tuner eats lots of battery life, so you need to be aware of it
- It's not a bad idea to always carry a spare BL-5C battery (fully charged)
Jun 20, 2009 | Nokia N72 Cellular Phone
Flashing lite on all handsets can't be shut off;
Yes you can go to settings menu and can switch off the backlight, this will save your battery power
Jun 16, 2009 | Panasonic KX-TG6700 Phone
Radio Communications Logo
66 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
