Question about Drills
I have a Dayton 3Z326 drill press that needs a spindle shaft and end piece (contains the spindle return spring). Anyone have one or know where I may obtain one?
rowdy45176
  • 2176 Answers
SOURCE: Chuck and shaft (spindle?) it was attached to fell off.
It sounds like it is a Morse Taper. If so what you need to do is clean bith the internal and external parts with something like brake clean to remove any oil or dirt. Then wipe both with a clean paper towel. Put a block of wood on the table or if you have enough room move the table out of the way. What you want to do is seat the spindle parts and you can either tap on the chuck (make sure threads are all the way retracted) or usse the feed handle to push and put pressure to lock parts together. If you have any more questions let me know.
Posted on Dec 29, 2008
SOURCE: The chuck will not return to the up position
On the left side, facing the drill press, opposite the spindle crank there should be a return spring in a housing. If spring is not broken, you can increase the spring tension so it will raise the spindle. If it doesn't, take the spring apart and see if it is not broken, or has become detatched.
berge
Posted on Sep 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Posted on Oct 13, 2009
cojon
  • 7 Answers
SOURCE: need manual for craftsman drill press model 113.213853
To correct that 2 degree angle, there is often an allen screw at the bottom of the table swivel. Look where the nut to loosen the table is. Under it is an allen head screw. loosen the table swivel a bit and turn that in an eight of a turn at a time, re tighten then remeasure.
Posted on Jan 04, 2010
  • 760 Answers
SOURCE: I have a Guardian Power floor model drill press.
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Posted on Jul 12, 2010
Drill will not rotate
Did you have to set the chuck into the spindle, or when you got the press, was the chuck already attached to the spindle? With the drill press I got (different brand), I had to set the chuck in the spindle and I put pressure on the chuck to set it in by placing a bit in the chuck and drilling in a piece of wood, which placed pressure on the chuck. If that's not the issue, check to see that the pulleys are turning ( flip the top open). Also check the tension of the pulleys (machine OFF) If there is nothing apparent or obviuosly not working, and if the press is new, yes, I would return it.
Nov 09, 2013 | Craftsman 23 hp 10" Drill Press with Laser...
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
I have a Dayton Drill Press Model # 3Z326.I need to attach the wires in the motor to the wires on the 110 wall plug but I do not know which ones go where.Help !
Do not try and reuse any of the damaged electrical. I buy a short extension cord of the appropriate gauge at HD and wire it to the switch and motor. Only disconnect one wire at a time .
Black is hot the screw color is brass, white is neutral and the screw color is shiny or chrome green is ground, it will be the plug prong that is at bottom of plug.
Apr 29, 2017 | Tools & Hardware - Others
How do oscillating drill presses work? I have an old Craftsman 8 inch drill press with spindle sanding capability, but the spindle will not oscillate up and down.
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Jun 11, 2011 | Craftsman Drills
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Mar 22, 2011 | Milwaukee Tool 4253 1 Drill 1/2 Mag Motor...
I need to get a downloadable copy of an owners manual for the Dayton 10" drill press, model # 4CY85
hi joel i can get you a users manual for your drill press do you have a fax machine ? or i could mail it to you let me know.
Mar 17, 2011 | Dayton Audio Dayton 4CY85 Bench Drill...
I have a Guardian Power floor model drill press. The spindle will not retract. I would appreciate knowing how to fix this and where I can get parts. Thank you. Bill Powell
Jul 12, 2010 | Delta 15 331 15" 115/230V Variable Speed...
Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
Jan 26, 2010 | Drills
The shaft piece that extends from the chuck is not straight
It would need to be replaced if you are talking about the spindle. Are you certain it is the spindle or could the chuck be causing the runout? I would take a close look at both.
Oct 12, 2009 | Drills
berge
Apr 30, 2009 | Turner Walker-turner Rockwell 20 Inch...
Drills Logo
118 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
