Question about Home
Seat is no longer heating. All other functions are working. Suggestions?
Unplugging and waiting a few minutes and plugging it back in. Power of and back on.
    Master:
  • 560 Answers
If the seat has no serviceable parts, replace the seat. Contact the manufacturer to find out if the seat is repairable.
Posted on Dec 28, 2014
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: UNIT FAILS TO ACTIVATE FROM
Seems that the unit has to be reset so that the processor detects the remote frequecny. It seems sure that the remote is working fine but the unit goes off to a hung postion when in power. This can be due to weakness in the processor or the detection side of the sensor.
If there is a possibility that water has seeped or if moisture is present within , there can be a silmilar problem. So remove power and try to keep the uni warmed up a litttle to make sure there is no moisture. If there is no improvement then the board/processor section has problems and must be taken out to be simulated and checked as the fault is erractic.
Posted on Jul 01, 2011
Got "Critical Alert Code 201" on Lennox air conditioning unit. Tech told me to shut off power to it then turn it back on, but that didn't seem to work. Any other suggestions?
Unplug the electrical. Wait 5 minutes and plug back in. See if that works. Have to wait a couple of minutes for system to reset.
Jul 02, 2016 | Heating & Cooling
I've tried all suggestions from other posts but still can't get Tub Clean Function to work.
Only suggestion I have is to try these old reset solution that work on some older lg washers: unplugg and wait 5 minutes or so, or unplug an d hold power button for 15 seconds, or unplug and the plug back in holding power button down for about 15 seconds then release. Good luck. (LG makes great products but their customer service and repair are horrible).
Mar 31, 2015 | LG Washing Machines
Why are the HDMI ports on PN58C7000YFXZA are no longer working?
Try unplugging the cables and plugging them back in at both ends -- HDMI cables sometimes lose contact after a while. This is especially true if the wires are not supported close to the plug -- they can pull loose.
Another possibility: reset the TV to restore functionality. Simply unplug it from the power, wait a minute, and plug it back in.
If that doesn't solve the problem, the circuit board may have failed. Your set is a refurbished model, and it's possible that this is a recurring problem.
Jun 08, 2014 | Samsung PN58C7000YFXZA 58IN PLASMA HDTV...
Where is the fuse for the heated seats in a 2007 jeep grand cherokee laredo?
Remove the ignition key. Unplug the HSM (heated seat module). It is under the passenger seat. You can easily accomplish this with the seat all the way back. Wait a few seconds they plug it back in. Start the engine. Turn the seats on. If the indicator lights come on for 2 seconds and then go out, further diagnostics is required. Hopefully they'll stay on and the seats will be working fine.
Thanks,
Ron
Feb 12, 2012 | Jeep Grand Cherokee Cars & Trucks
My 2004 Maxima power windows, power locks, power sunroof all stopped working at the same time. Fuses all look good. Any suggestions?
does your power seat work?if not unbolt seat lift up and unplug connectors coming up from floor to seat.wait a couple minutes for internal circuit breaker in body control module to cool and reset and see if your other components start working.if so wiring in seat has grounded out to seat frame and sometimes se it crushed under metal seat pan below cushion.usually easy to insulate and repair once you find it.
Feb 27, 2011 | 2004 Nissan Maxima
Hi, my router won't le tme connect to the internet. I have unplugged it, waited a few minutes and then plugged it back in. Re-booted it, and still no connections. Any suggestions?
you probably need to unplug power on your router too.
Unplug both power plugs and wait 20 seconds. Then plug back power to your MODEM FIRST.
Wait 1 minute to make sure the connection get an ip address.
After that, put the power back to your router.
Wait 20 seconds and try the connection with your computer.
If it doesn't work, restart your computer.
Hope this helps!
Feb 21, 2011 | D-Link DIR601 WirelessN 150 Home Router...
My wii has no power at all. ive unplugged and reconnected all the wires put there is still no power, and every thing else in the outlet works
I just had the same problem moments ago, if you unplug the power cord from the wall and the unit and let it sit for a few minutes, then replug it back in, it should come back. Unplugging and plugging back in without waiting won't work, you have to wait 2-5 minutes.
Dec 16, 2009 | Nintendo Wii Console
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Home Logo
87 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
