Question about Cameras
Just need a battery cover for my cameraDXG5c8v hd
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Go on-line and enter camera info. DXG5c8 HD/parts. Should get a listing of parts!
Posted on Dec 12, 2014
How do you replace the battery in a Samsung HMX W200 video camera
take the cover off and way ya goo replace it put the cover back on and play
Feb 19, 2015 | Samsung HMX-W200 Waterproof Full HD 1080P...
How do I remove the battery cover on a 2014 wide glide
If there is no visible way to remove cover then you may need to pop it off. Try pulling the cover off, be carefull of your knuckles. GOOD LUCK FRIEND.
Nov 11, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
Hp safeboot password removal
I'm assuming this is a desktop since you said motherboard. First take cover off then locate small round battery (looks like watch battery) remove it and count to 15.or 20, replace battery and cover. You will have to reset time but all memory should be cleared. You should go to Hewlett Packard Compaq support. If you find this didn't work, it's in your HD. computer.> HD >properties>tools>check disk> all else fails reformat.Hope you have the oringinal windows disk
Dec 10, 2011 | HP Compaq 6735s Notebook PC
Im not getting any display or sound on my acer 4520.It comes on but that 's it.
One
Check all your media slots have nothing in them, i.e. USB, CD/DVD drive and flash drives etc. Try a start with AC cord only, and no battery, then no AC with battery only, if that didn't work then let's move on.
Two
1. Remove the battery and AC cord. Remove the bottom cover/covers of your laptop and make sure the cooling path is free of fluff and dust. Check the heat sink on the CPU is not loose, if so tighten the screws back down that hold it on.
2. Remove and reseat your RAM modules.
3. Replace your covers.
4. Hold down your power button for 1 minute (Battery and AC still disconnected).
5. Replace your AC power (not battery) and turn on. This is called a hard reset. If it works COOL, then replace your battery. If that didn't work then let's move on.
Three
Remove your HD, and try starting your laptop. If it goes through the POST, and then a black screen appears with the message Operating System Not Found, and remains at this screen, then your HD is faulty. Replace with new HD. If that didn't work then let's move on.
Four
Next prove you dont have bad RAM. You need to identify what one is faulty. Remove all the RAM. Take one stick at a time, and swap it around the RAM slots to see if the laptop will start. You have now identified the good RAM. If each stick produces the fault, then you may have two sticks of bad RAM or a bad RAM slot. Borrow or buy known working RAM. If that didn't work then let's move on.
Aug 23, 2011 | Computers & Internet
I get an error that says HDD init failed connect to pc when my computer doesn't recognize it so I cannot format the HDD?
The main hd is unpluged. Unscrew the screws nezt to battery. Slide left the back cover just like the battery cover and plug the hd back in. piece of cake!
May 04, 2010 | Gateway Photo Jukebox GCM-4 MP3 Player
2005 HD Sportster - How do you get the rubber clip
I'm not familiar with the type of rubber clip you're talking about but if it's anything like a wellnut, this is how you install it. It's just a rubber piece that the projection on the battery box cover pushes into I think.
First lubricate the rubber clip with silicone or brake fluid. Then using a small pin punch, push it into the hole. Make sure you don't use anything sharp or it'll punch out the backside instead of "stretching" the rubber clip so it'll go into the hole.
Oct 10, 2009 | 2005 Harley Davidson XL 883L Sportster
Flip ultra hd not charging
I had the same problem, but it seemed to be a bit more sporadic. I'd occasionally get the "Charging Paused - Check Battery Pack" error. The battery pack itself looks a bit strange, since the white plastic covers the bottom, right side and it seems that there is no possible way for the battery to make contact with the camera. However, I saw the following suggestion on another site (which the poster claimed came from Flip technical support), and this technique worked for me:
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
May 20, 2009 | Pure Digital Flip Video Ultra Camcorder
No Operating System found
You can open the harddrive cover to check.
Most likely the drive is broken and needs to be replaced.
Its going to cost you, but take the laptop to a repair service / shop / center.
Thats if you dont have warranty.
You can try reconnecting the harddrive.
But If it already was well connected. Its most likely broken.
Mar 09, 2008 | Toshiba Satellite A105 Notebook
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
