Question about GE Dryers
How to take the front of a GE front loading Dryer
Need to fix power button,But cant get the front top panel off it only has one screw in it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Most appliances just have clips that snap into predrilled holes. To take apart just wedge a screwdriver between the sections and carefully pry apart.
To avoid scratching put electrical tape or other protective cover over screwdriver tip to avoid scratching cover.
Posted on Dec 12, 2014
How do I remove the lid off of a GE dryer
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Apr 01, 2015 | GE Dryers
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
Power button stuck will not stay pushed in but does work why?
Sounds like simply the mechanical aspect of it has failed somewhere. Get your complete model # and enter it into the search box at repairclinic.com. You should be able to order a new one and replacement is possible if you're adept at all with such repairs . . Sounds like a reasonably fix. .
Jul 20, 2014 | GE Dryers
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do I open the case on a GE dryer?
Of corse there is some variation among different GE models, but in general there will be one of two methods. Disconnect from power, then: 1. Open door and look for screws from top area of front panel into the dryer top to allow top to open, which in turn allows front panel to be removed. 2. If no screws, then use a putty knife to push in on the two clips which secure the top to the front panel. (right in the seam, front panel to dryer top, a couple inches in from each side.)
Sep 22, 2009 | GE DBSR453EBWW Electric Dryer
How do I open the case on a GE dryer? I am trying to replace the drum belt on my dryer and cannot open the case to gain access to in the inside of the machine
The belt goes on around the drum from the front.
Sep 22, 2009 | Dryers
Dryer squeaks when loaded
LOOK FOR ANY SCREWS ON THE FRONT PANEL, AT THE VERY BOTTOM OR TOP IF NO OBVIOUS ACCESS PRY THE TOP UP AT THE EDGES BETWEEN THE TOP AND THE FRONT PANEL
Apr 09, 2009 | GE Profile DPSB620ECWW Electric Dryer
NEED TO KNOW HOW TO TAKE THE DRYER APART TO FIX IT
serviced from the front, open the door and lood at the rim of the opening the should be 2 phillips screws holding the main top assy down, after removing the top youll find 2 more screws securing the front panel
Mar 07, 2009 | GE Dryers
Dryer no heating how do I get to the fuses and the heating elemet
using a wide flat screw driver pry the top up at the edges betwenn the main top and the front panel. Lay it down on it's back for this. Now look for your door switch wires and undo them. Now look inside the front panel toward the top and remove 2 attaching screws or hex screws. Lift panel at top and remove. Now undo 3 screws in middle of inside drum and pull drum out after un-doing belt. There you should find your heat element and all the thermostats and the thermal fuse should be labeled. If heat element is not broken then chances are your thermal fuse is bad replace it
Feb 28, 2009 | GE DVLR223 Dryers
Dryers Logo
81 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
