Question about Jeep 2012 - Patriot
When use the auto start the only light that comes on is the right rear. as soon as i turn the lights on, it goes out.
I have had the wiring checked from back to front, changed light bulbs
    Sergeant:
  • 286 Answers
After market module is bad,,
Posted on Jan 02, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Not enough info. To know what your talking about!
Posted on Dec 12, 2014
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
69 turn signal problem left turn signal not working. right turn signal causes both to falsh
it's the grounds if they're both flashing fast it's definitely grounds take a test light and see if its got power goes through the test light grounded to the frame and if the light comes on then it's definitely your grounds
Jul 29, 2014 | 1969 Pontiac Firebird
Mitsubishi montero stalls, but is able to start
must have a bad o2 sensor need to check with a scanner auto zone and advance auto parts do it for free.
Jan 17, 2010 | 2001 Mitsubishi Montero
REAR BRAKE LIGHTS DO NOT COME ONLY TAP LIGHT IS
Check for power at the turn signal switch. White wire comes from brake switch switch into the turn signal switch. The brake light switch is working because the high mount brake light is working..right? Do the turn signals work ok? if so, then the wiring is OK. The brake signal wires that come out of the turn signal switch are dark green(right) and yellow (left).
Oct 27, 2009 | 2001 GMC Safari
Service engine soon, TCS off, SLIP
The oil change wouldn't cause this problem. Just in-case, check the engine oil level.
There are many emission sensors in the car that will make the engine light come ON. Best way to find out what's going on is to have an auto-parts store hook up a engine code reader and tell you what the code means. Most auto-part store will do this for free.
Oct 11, 2009 | 2004 Nissan Quest
All lights work and brake light at top works. brake lights on bottom left and right don't work. It was hook up to trailer wires connection. going down the road and when you turn on the right turn signal...
Check a few things...
- The bulbs
- Check for ground at brake lamp connectors
- Check your wiring at the connectors for power
- Check for another fuse blown
- Do not hook up the trailer until you fix the ground problem on the trailer
- On some models, there is a module to control the rear/trailer lighting system. There may be a problem in the module.
Jul 24, 2009 | 2000 GMC Safari
Rear fog light blows fuse
Check the relay for these lights. Might be melted or frayed wires. Also check any existing wires coming to/from the lights. These are usually run in series with something else and could be just a ground/hot wire popping the fuse.
May 21, 2009 | 1997 BMW 318
THE BRAKE LIGHT WARNING LIGHT COMES ON AND THE DRIVER SIDE BRAKE LIGHT DOESN'T WORK. I CHECK AND CHANGED THE BULB AND IT'S NOT THE BULB. IF I TURN ON THE HEADLIGHTS OR PARKING LIGHTS, THE WARNING LIGHT...
well here's a start towards ur problem, due to the auto circuits u have an open return to the negative side of the battery. Have you done anything with the vehicle's systems before this started? the reason fo the strange lighting is that a positive voltage is being applied to what normally would be return side. You will need to get an electrical diagram if possible to pin point area if as previously asked didn't occur.
Mar 02, 2009 | 1997 Toyota Camry
Trailer wiring for 06 GMC Canyon 4x4
exactly what does it do? please explain what happens when you press the brake turn on the light than brake signals ect.....
Aug 13, 2008 | 2006 GMC Canyon
Jeep 2012 - Patriot Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
