Question about Drills
How to replace a trigger on a hiltI SD 4500 screwgun?
3 Suggested Answers
  • 33 Answers
SOURCE: Hilti TE6A battery dril 36volts,trigger problems
what about the brushes. even if they arent worn completely down they sometimes will not have enough pressure on the commutator tabs to keep the tool running. if it works better upside down or sideways that is often an indication of faulty brushes. the springs that hold the brushes against the commutator may also be weakened to the point that they don't properly force contact. you may also have burned or blank spots on the commutator/armature.
try new brushes and make sure the associated wires arent broken, pinched or otherwise damaged. also clean the commutator with a polishing cloth or very very very fine sandpaper, being careful not to scratch, groove, or otherwise damage the tabs. also, the bearings that fit in the housing to stabilize the armature may be worn or seizing, which will cause the armature to move erratically and/or bind.
if all of these things have been done, and the problem STILL exists, then probably the motor itself (armature/field) is breaking down. the brushes and bearings at least are probably in stock at a local tool repair shop, and of course all parts can be purchased through hilti.
Posted on Dec 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: cord got cut on my dewalt screwgun. dont know how
Have you removed the old cord yet, if not make a crib sheet showing where the wires go. If the wires push into the switch use a staple and bend one of the long ends and push into hole and when pushing gently pull the cord wire out. Let me know if you need any other help
Posted on Mar 16, 2010
How to stop buzzing sound on hilti te 706-avr
  1. try to pull the trigger more back then its stand free , because i think that a dust ring insite the trigger was come loose and get inside the trigger so it will not fully come back in its normal rest position but its stands maybe a little fraction triggered , replace the switch .
Apr 24, 2015 | Hilti Drills
I'm looking for a Hilti manual..Screwgun SD 4500
Hilti.com has parts breakdowns or if not it has a contact number for Hilti so you can call and get one.
Jan 11, 2014 | Hilti Drills
Trigger sf 4000
I would contact Hilti or a Hilti dealer. Here is a link to their site. You will have to remove any fasteners that hold the housings together so that you can replace the switch.
Hilti
Aug 25, 2012 | Drills
Trigger switch on te22 dead.can I get a replacement or will something else fit
you can go to Hilti direct or find a local dealer by going to "hilti.com" or calling them at 1-800-879-8000 and you can get the replacement. I would not try another switch.
Feb 12, 2011 | Hilti Hammering
I own a Hilti SF 150-A 15.6 volt cordless drill ( non hammer type ). I need a trigger assembly for it. Where can I order one?
As i know Hilti has a free of charge repair or replacement of defective parts; Hilti tools are covered by a lifetime manufacturer's warranty against material or manufacturing.Call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Hilti Cordless Drill Driver SF 151A 20Ah...
How to change the tip?
Just pull it out. If it is rusted stuck, get a pair of pliers on there and give it a yank. It will come out.
Jul 13, 2010 | Bosch SG45 4500 Rpm Drywall Screwgun
Bosch sg 45 drywall screw gun
You have to replace the entire depth guage assembly (the front plastic pieces where the bit driver is). Unfortunatly Bosch does not make the individual pieces for this gun. Any Bosch service center will be able to supply you with this piece
Apr 10, 2009 | Bosch SG45 4500 Rpm Drywall Screwgun
Drills Logo
71 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
