WORKS FOR CHANNELS BUT NOT VOLUME AND MUTE - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Try by set-up the remote control to TV; with an other code said for the TV brand. Check whether the new codes works for all functions. If not try an other one. This is the procedure to set up a universal remote control. Actually it is a trial and error method. Note all the set-up codes you have tested, and select one; which give the maximum functionality.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 13, 2014
2 Suggested Answers
james tv man
  • 88 Answers
SOURCE: nothing is working but the volume and mute
Some of these remotes are also made to run other components,so be sure to press the "tv" button and try the vol and channel again!
Posted on Jun 04, 2010
How do I get the volume to work, it doesn't work manually or with the controls
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 18, 2014 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
One channel muted until the volume is turned up
This problem is usually dur to some corrosion in the speaker relay. If the relay can be opened, burnish the contacts and you should be OK. The higher volume creates a higher voltage that can "jump the gap" so to speak. Once the connection is made it will remain. That is why lowering the volume will work.
Dan
Apr 14, 2010 | Yamaha AX-396 Amplifier
Friend turned volume up.. now display/volume died no sound
Sounds like your friend burned out the power amplifier. That would be the only reason none of the channels work. Unless the unit was muted by accident and no one checked the mute function - though I doubt that.
Jul 04, 2009 | Denon Audio Players & Recorders
My h500 connects to my ps3 but no one can hear me
On the H500 - press both volume buttons at the same time and hold until you hear two descending tones to ensure mute is disabled. Also double click the volume control on your computer to open the volume controls and make sure the microphone channel isn't muted.
Jun 21, 2009 | Motorola Mobility H500 Headset
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Jan 09, 2009 | Televison & Video
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
