Question about Garden
Carburetor adjustment for efco 152 chainsaw - Garden
    Problem Solver:
  • 23 Answers
Before attempting the following task, make sure you are not wearing anything which might catch in moving parts and that the floor around you is clear and that the saw is firmly held in the vise and that you are wearing suitable hearing protection.
I Totally agree with Eugene and his statement about original settings, but be careful not to over-tighten mixture screws when screwing in to seat, as carb body is aluminium and screw is steel, so overtightening the screw could distort the jet/seat in the carb body and that is irreversible, the carb will be ruined if you do that.
There are two screws for mixture and one screw for idle revs/speed. The mixture screw nearest the engine is the idle mixture and the one furthest away is the high mixture.
To adjust the low mixture first mount the saw in a vise carefully so the bar and chain is pointing away from you. After you have done the initial adjustments as Eugene has described, start the saw and after warming it up for a short while, let it idle and then screw the idle screw in very slowly until the engine starts to rev up and then a little bit further and, just when it starts to die, back off the screw 1/2 a turn turn down the idle revs/speed with the third screw to to a speed where the chain does not move. When that is done it does not need to be touched again
To adjust the high needle a rev counter is necessary, but in the absence of one, try the following and if it does not work, take the saw to a professional as the wrong high mixture could blow the engine.
Make sure the vise is tight on the bar and that the chain is in no danger of hitting anything when it turns fast, rev the saw up to full throttle and listen to the engine (wearing ear muffs) and carefully keeping your clothes clear of the chain, turn the screw out until the engine starts to slow down, and then screw the screw in until the the engine starts to 4 stroke, ie starts to cycle a tiny bit (the revs go up and down a little) and that is the correct setting for that saw.
Posted on Dec 13, 2014
  • 1,169 Answers
Initial settings is 1-1/4 counterwise from seated position.
Adjust for best idle first then best full speed with a slight 4 cycling sounds.
Posted on Dec 12, 2014
  • 398 Answers
SOURCE: I need help with a carburetor adjustment on my chainsaw.
this site gives alot of helpful hintshttp://www.arboristsite.com/showthread.php?t=5208
Posted on Mar 02, 2009
  • 120 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
  • 4088 Answers
SOURCE: adjusting carburetor
Does saw try to run? Initial settings are about two turns out from CW stop. Set high speed (on warmed up engine) to 4-stroke with no load, but smooths out with light load (cutting wood). Idle is set for fairly smooth idle, but engine picks up with throttle without lag. Idle speed setting is somewhat below chain drive clutch pickup, but allows engine to keep running.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the carburetor metering lever adjustment for an
Clarification Request
Posted by slohry on Apr 10, 2009
What kind of carburetor does it have? Zama, Walbro? And what model carb?
No response to clarification request... delete this question.
Posted on Sep 16, 2009
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Setting carburetor
David, may vary by make, model and engine size. I turn the L(low) and H (high) speed screws in till just seated(bottomed out) lightly, then I turn each screw out 1 complete revolution, start saw and tweek adjustments from there on the L and H. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Chainsaw Carburetor
https://store.chainsawr.com/blogs/tuning-and-repairs/1126042-adjustment-and-tuning-of-a-chainsaw-carburetor
Adjusting chainsaw carb
Jul 03, 2016 | Garden
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
My efco 152 chain saw tickes over , but when I reve it up it holds back
If the exhaust is smoky turn the needle valve marked with an H in (clockwise) about 1/8 of a turn. If not turn it out 1/8. If the fuel in it is older than a month Dump it out and start with fresh fuel before adjusting the needle valve.
Feb 25, 2015 | Efco 18" 51.7cc Gas Chain Saw - 152-18
My efco stark 4400t strimmer revs so high it cuts out.
Turn the high side adjusting screw CCW a 1/4 to 1/2 turn.
Feb 25, 2015 | Garden
My chainsaw is idling high
Several reasons for that,
1. Air is getting into saw through leak in manifold
2. Carb idle/rev screw is set too high
3. Carb idle mixture screw is set too weak (uscrew it a tiny bit and check) See my other answer link below for advice on that:
4. Fuel filter in tank is partly blocked reducing fuel flow. They should be changed once a year on a domestic saw, more often on a professional saw.
5. The springs on the clutch are weak allowing it to engage at too low a speed.
Dec 12, 2014 | Garden
Efco chainsaw
Check carburetor,needs cleaning or choke is stuck
Sep 05, 2014 | Garden
I am also looking for a user's manual for the same chain saw sharpener. EFCO INDUSTRIES FL6
Here is a link to efcopower. Pretty good chainsaws; no chainsaw sharpeners!!!
http://www.efcopower.com/indexPri.jsp
Their parent company
emak Italy. No chainsaw sharpeners!!!
http://www.emakgroup.com/
Is there a tag that says Efco Industries?
I think this is an urban myth among chainsaw folk!!! Please do what can to stop this mis-information!!!
Tecomec chainsaw sharpeners (Italian subcontractor for Oregon)
http://www2.tecomec.it/database/tecomec/tecomec.nsf/prcat/AD47E80A73B834FBC1256E670057DEDA?OpenDocument
Click the appropriate model, at the bottom of the page is a pdf. There are both 240 & 120 VAC models, use care. HTH
Lou
Nov 13, 2009 | Garden
Manual for Efco FL6 Chain Sharpener
The chain saw chain sharpener is an "efco Industries" chain sharpener that was made in Italy. Type # 136 & LR# 36941 have a good day please rate bama46, thanks
Aug 22, 2009 | Garden
Require user's manual for an "efco" chain sharpener.
I have a user'manual for your efco chain sharpener. Send your mail adress.
Apr 05, 2009 | Garden
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
