Question about Maylong Tablets & eReaders
I need to order the a/c home adapter cord for the Maylong Mobility Tablet
How to hard reset maylong m-270.
look for a tiny hole on the side.Use a paper clip to reset. If not, try turning unit off then press power and volume DOWN at the same time to restart. use the manu after that. If that desnt work, try same thing with volume UP.
Nov 27, 2015 | Maylong Mobility M-270 7 4 GB Tablet -...
My friend forgot to give his username and password for maylong mobility tablet
Hi Trent:
The logical thing to do would be to ask him for it.
If he wants you to have it I would expect that he will give it to you.
Nov 20, 2015 | Maylong Mobility 7" Tablet Black Color...
Forgot password when try to put it recovery mode wont go past blank black screen
Power button , up volume , n home button will reset it and reset to put new password or just hold power button until it goes off and then hold power button until it comes on then off then press till it comes on
Mar 27, 2015 | Maylong Mobility M-270 7 4 GB Tablet -...
I tried powering up my tablet but it doesn't power up after many tries with many cords and Sears won't take it back. What is wrong?
Hi! I will try to assist you:
1. Make sure the battery is charged enough for the tablet to power on or (if it is not) if you can charge it. An easy way to do thisa is to plug in a charger and see if it indicates that it charges.
If it does not charge, then:
a) The battery is faulty or
b) Something is wrong with the adaptor or the "charge-circuit"
In order for a) and second part of b) to be checked, your tablet needs to be opened!
2. If it charges, then it might be the power button. Try to press it hard enough (try not to break it though) in order to make sure it is not a little bit broken or moved. If still nothing happens then your tablet has to be opened!
3. The screen might be faulty as well.
4. If it is none of the above, then it might be the mainboard. In order to make sure it is not the mainboard, you would need to connect it to an external monitor and see if it works with the external one (I think there is no such option in your case, though)
I assume you wish to experiment-check it by yourself. If you just need a new one, then for instance:
1result for maylong universe
Dec 06, 2014 | Maylong Tablets & eReaders
Maylong mobility tablet's charger
Hi E/BAY HAS SOME MAYLONG CHARGERS. type in e/bay search .( Maylong tablet charger ).cheers
Jul 02, 2017 | Maylong Mobility WiFi Tablet PC
Tablets & eReaders Logo
52 people viewed this question
Top Maylong Tablets & eReaders Experts
Todd Arndt
Todd Arndt
rugby prop
Ted Maxwell
Are you a Maylong Tablet and eReader Expert? Answer questions, earn points and help others
