Question about Optics
Can I get a repair manual for the Winchester 333 air rifle?
I have 2 of these, neither has the power to put a pellet through the barrel. One has a number of pellets jammed in the barrel. Need to know how to safely disassemble, repair, etc.
  • 8 Answers
SOURCE: cross hairs keep turning
I don't shoot BB guns, but I looked up your gun/scope combo. It' a $65 Chinese product. At this price level you cannot expect a decent scope or rifle. It just can't be done. The scope will not be worth fixing.
Posted on Nov 26, 2008
  • 117 Answers
SOURCE: This is a new pellet rifle, but it is not getting
Lubricate everything generously with Marvel Mystery oil.Your new pellet gun is probably leaking around the seals.Oil improves the seals.Be sure to wipe off excell oil before shooting.
Posted on Mar 25, 2009
Adrian762
  • 425 Answers
SOURCE: i took apart my crosman .177 pellet rifle, and
See the answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
Posted on Feb 08, 2010
agent91
  • 2100 Answers
SOURCE: How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
Posted on Aug 04, 2010
  • 1082 Answers
SOURCE: when I **** the barrel to compress air it won't
If it new, it must have a warranty of some kind. Use the link below to contact customer service for help.
Crosman recommends that you take to a service center, and adds the following. >DO NOT ATTEMPT TO DISASSEMBLE IT< Your Phantom requires special tools and fixtures to repair it. Any disassembly or modification not performed by an authorized service center will void the warranty.
Crosman customer service
http://www.crosman.com/airguns/service
Posted on Dec 06, 2010
I have a F4 crosman air rifle and I can't find the place where the co2 goes I need help
It is a break barrel air rifle that when it is cocked the piston is pushed back drawing air into the cylinder so that when the barrel is closed the breach seal covers the transfer port squeeze the trigger piston flies forward forcing the air through the transfer port into the barrel accelerating the pellet up the barrel and towards the point of impact
It is not a co2 powered air weapon
Oct 20, 2017 | Crosman Optics
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ...
www.gamousa.com > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
Nov 07, 2015 | Gamo Bone Collector .177 Caliber Hunting...
Why my crosman recruit .177 shoots inconsistently?
I hear that the ammo has alot to do with that. .BB on a unrifled barrel gun are not as good as pellets. Lead pellets ride on the rifling in the barrel. And also your sites could be out of line. One man took the inner barrel out of the outer barrel and bent it over his knee slighty.His rifle was shooting high. On his daisy model # 880 Powerline.. But I would not go that far.A unrifled barrel is best for BB's.only.Hope I can help you out.Yours truly Joseph Alexander Bagli.
Jul 10, 2012 | Crosman Recruit Multi-Pump .177 caliber...
Ilive in indiana and i have a problem with ratcoons . so i set out to buy a good air rifle , i though i had one then i put a bb .177 cal , in my brandnew BEEMAN air gun ,the the bb feel out the barel ......
Are you sure its a bb gun and not a pellet gun? Usually bb guns have a magnet on the bolt, that keep the bbs from falling out. Pellets don't roll so the won't roll out the barrell.
Mar 03, 2011 | Beeman 1024 Takedown Rifle, Scope, Rings &...
What is the best lubricant for keeping the rifled barrel clean and how often should it be lubricated?
Oil in the barrel an air gun can lead to bad things, If you are worried about corrosion, lube with light oil then remove as much as possible with a dry swab. It doesn't take much to provide corrosion protection. I rarely clean or lube my air rifles, maybe 2 times/year or every 1,000 shots. It really is not necessary unless your accuracy deteriorates.
Here is an excellent article dealing with this issue:
http://www.air-rifle.net/cleaning/cleaning.html
Apr 26, 2010 | Crosman Optics
Where can I buy repair parts for daisy 880? also need schematic of rifle. Bill
Daisy.com should have everything especially a owners manual with parts list. They don't fool around with safety.
Feb 13, 2010 | Daisy Winchester 1000B Synthetic Stock...
Pellet gun will not fire
If its your first time using it, make sure the bolt is pulled back before pumping it. Pulling back the bolt resets the sear and drops the valve.
If its well used, either your pump head o-ring or valve has gone bad.
Jan 20, 2009 | Daisy Winchester 1000B Synthetic Stock...
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
