Question about Lincoln Welding Tools
Is it possible to fit a for a lincoln mig/mag welder spoolgun ,on an elektra beckum mig/mag welder?
Realy,ihaven t try anything jet,but soon i want to try some aluminum weldings, andtill so far i have noticed,it looks like iwill need a spoolgun for my elektra beckum mig welder wich is mounted with standard welding torch
2 Suggested Answers
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Hot all the time
relay / contactor has stuck in the on position
Jun 15, 2013 | Lincoln Electric LE 83180 Century...
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
Welding gun doesnt respond when trigger is pressed
First determine if the wire drive motor responds to the trigger.
If not, then there is a fuse for the motor I believe.
If the motor tries to drive the wire, the wire MAY have jammed into the side of the transfer tube or the end fitting preventing it from moving.
Mar 01, 2010 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Spoolgun wire speed starts out slow then speeds up.Tried another gun and it does the same thing.
Check the Clutch on the wire reel, usualy a bolt centred on the hub this is possibley too tight, slack this off and try again, Tack the tension off the WFR check the speeds are viriable through the range,
Dec 30, 2009 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Plugged a 110 into 220 volts turned it on heard it pop now it wont work
check for an inline/or internal safety fuse could be pop noise if no fuse burnt up circuit board
Oct 28, 2009 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Trying to choose between a hobart mig welder and a lincoln electric - features similar. Any comments ?
Hobart and lincoln are extreamly good units, it boils down to your personal preference, if possible, try them out ask for a demonstration.
Jan 15, 2009 | Welding Tools
Welding Tools Logo
49 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
