Question about Vizio Televison & Video
My Vizio E422VL wont turn on how do I fix it?
Model E422VL. I have tried taking out the power cord and resetting the TV. Likely to be a problem internally.
    Top Expert:
  • Vizio Master
  • 34,170 Answers
The problem could be an open fuse or a failed power supply.
Posted on Dec 12, 2014
42" Vizio Model E422VL intermitant audio loss and horizontal pixilation band in center of screen. Is this a fixable condition or the beginning of screen failure that will require screen replacement ?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Dec 16, 2016 | Vizio E422VL 42 in. LCD HDTV
How to fix a vizio 40" tv model E422VA dont turn on
Check the PS first since your set appears to be totally dead.
Nov 18, 2015 | Vizio E422VL 42 in. LCD HDTV
My Vizio E422va turns on but wont go past the start screen with the Vizio logo. The remote won't work either. It's like it freezes at start up.
Corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2015 | Vizio E422VL 42 in. LCD HDTV
My Vizio E422VL was working fine. I moved it to another room and it continued to work fine. A few hours later the TV will not power up, no lighted Vizio logo on the front. The TV does have power becau
You may have a power board issue. It may have simply blown the internal fuse also. Couldn't hurt to check it? Moving it may have possibly jostled it? Especially if you get no 'Power light blibs' on and offs when you plug it in. Usually these flat panels have some power light diagnostics. Like 3 on/offs then full off says power supply.
Dec 07, 2014 | Vizio Televison & Video
My Vizio E422VL is only a year old. It has been working perfely fine and now it wont turn on at all. The remote and the on set switch don't work. Any suggestions?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 03, 2014 | Vizio E422VL 42 in. LCD HDTV
My Vizio 3D e3d320vx wont turn on !
I would say 75 percent of all lcd tvs that don't come on have faulty capacitors. The parts were under rated at time of design. It will take tv repair knowledge to fix y our TV!Capacitors are fairly cheap,but labor will cost a lot more. I have fixed 90 percent of lcds that I get to repair.The other 10 percent are not worth fixing, due to broken screens or costly circuit boards.So you will have to weigh the costs on repairing or getting another TV. Sorry,but I see no other options!
Jan 14, 2014 | Vizio L32 32 in. LCD HDTV
I turn my vizio on then it just turns itself off
Tries tv unplug,replug it back like an hour later.By letting the tv resetting itself back to the factory setting.The tv should be working again,if have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish power supply board for the replacememt.
Jan 30, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Televison & Video Logo
144 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
