Question about Atb 63 Ac Motor Ab63/4c-7 0.34 Ph-1 1420-1710rpm 230v & Procon Pump 10204
Assembly diagram for procon series 1 pump
Can not reassmble
What does LD code mean on my whirlpool cabrio washer mean?
Ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Aug 20, 2014 | Whirlpool Washing Machines
Where is located the fuel pump for mazda b3000 2003
Check in the next diagram (click over imge for zoom)...
Fig. Exploded view of the B Series Pick-up fuel filler assembly and pump mounting
May 01, 2011 | 2007 Mazda B3000
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
The dl. Code comes on
DL = Long Drain Ld flashes when the water level does not change after the drain pump is on.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag Bravos quiet series 300 washing machine stopped. Won't drain. A message Ld shows. Not sure what to do
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
test.
control.
repeat step 1.
pump motor.
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Nov 21, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
I am getting no diesel into my fuel filter is their a electric pump in my tank or is the fuel pump part of the injector pump
Fuel Pump REMOVAL & INSTALLATION Navajo and B Series Pick-up Models NOTE: To gain access to the fuel pump, it is necessary to remove the fuel tank.
  1. Depressurize the fuel system and remove the fuel tank from the vehicle.
  2. Remove any dirt that has accumulated around the fuel pump attaching flange, to prevent it from entering the tank during service.
  3. Turn the fuel pump locking ring counterclockwise using a locking ring removal tool and remove the locking ring.
  4. Remove the fuel pump and bracket assembly.
  5. Remove the seal gasket and discard it. To install:
  6. Put a light coating of heavy grease on a new seal ring to hold it in place during assembly. Install it in fuel tank ring groove. Fig. 1: Fuel pump and sending unit used on the B Series Pick-up regular cab 89685g02.gif
    Fig. 2: Fuel pump and sending unit used on the B Series Cab Plus Pick-up 89685g03.gif
    Fig. 3: Fuel pump and sending unit used on the Navajo 89685g04.gif
  7. Insert the fuel pump assembly into the fuel tank, then secure it in place with the locking ring. Tighten the ring until secure.
  8. Install the tank in the vehicle.
  9. Install a minimum of 10 gallons of fuel and check for leaks.
  10. Install a pressure gauge on the throttle body valve and turn the ignition ON for 3 seconds. Turn the key OFF, then repeat the key cycle five to ten times until the pressure gauge shows at least 30 psi. Reinspect for leaks at the fittings.
  11. Remove the pressure gauge. Start the engine and check for fuel leaks.
MPV Models
  1. Relieve the fuel system pressure and disconnect the negative battery cable.
  2. Remove the rear seat and lift up the rear floormat. Remove the fuel pump cover.
  3. Disconnect the sending unit/fuel pump assembly electrical connector and the fuel lines.
  4. Remove any dirt that has accumulated around the sending unit/fuel pump assembly so it will not enter the fuel tank during removal and installation.
  5. Remove the attaching screws and remove the sending unit/fuel pump assembly.
  6. If necessary, disconnect the electrical connectors and the fuel hose and remove the pump from the sending unit assembly.
  7. Installation is the reverse of the removal procedure. Be sure to install a new seal rubber gasket. Fig. 4: Remove the rear seat and floormat to service the fuel pump 90975g06.gif
    Fig. 5: Removing the fuel pump assembly 90975g07.gif
Aug 17, 2010 | 1995 Mazda MPV
Replace heater core in 2005 ford taurus
This is a very big job, You must remove the complete dash assembly, then remove the heater box assembly , then replace the heater core and reassmble everything that was removed to gain access to the heater core.
Apr 18, 2010 | 2004 Ford Taurus
Kenmore oasis he top loader shows LD error code. got back panel off, now what?
Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96˝ ? • Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How do i remove front brake discs on my Lucida 4x4
Remove the front wheels. Remove the brake calipers (usually held with two stud bolts on the stub axle assembly.(look behind the disc)The discs should then pull off. On reassmbly ensure the caliper bolts are fully tightened.
Mar 05, 2009 | 1997 Toyota Previa
Atb 63 Ac Motor Ab63/4c-7 0.34 Ph-1 1420-1710rpm 230v & Procon Pump 10204 Logo
110 people viewed this question
Top ATB Plumbing Experts
Tom Chichester
Gil Shultz
Are you an ATB Plumbing Expert? Answer questions, earn points and help others
