Question about Saeco Odeo Giro Automatic Espresso Cappuccino Maker Built In Grinder
The alert light on our beloved Saeco Odeo Giro is flashing. I checked that the brew group is firmly engaged, water is in the tank, coffee in the hopper. What else would trigger this light?
Re-inserted the brew group, I checked that the brew group is firmly engaged, water is in the tank, coffee in the hopper.
4 Suggested Answers
SOURCE: My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Posted on Apr 10, 2009
  • 81 Answers
SOURCE: I have a new Saeco Odea Giro Coffee Machine and
Is it the red light flashing and the water button light also on? That means air in the system.If the flow of water is not steady, make sure water tank is fully push in.
The next thing you can check is the test mode which is not given in the manual.Hold down water button and switch on the machine,you will see the lights turning on alternately in anti clockwise direction. Release the button.Turn the dial to the right and press the coffee button, water pump will work.Turn on the steam/water knob and keep pressing the coffee button until all the air is purge out. Dial on other positions will test other components of the machine,such as grinder, solenoid valve , brew group,etc: I hope you can solve your problem with this information.
Posted on Feb 22, 2010
ercupa190
  • 12223 Answers
SOURCE: Can I replace the grinder in my saeco odeo giro?
yes see the next steps. and fix it. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the HEATING ELEMENTS and the switch, thermostat, and timer .
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Posted on Oct 16, 2012
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
Saeco Giro flashing
Alarm light:
on and slowly fl ashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed, the service door is open.
Jun 24, 2014 | Saeco Coffee Makers & Espresso Machines
Why are the used grinding pads on my saeco odeo giro very loose and watery
I can personally confirm this fix from another similar question works: "I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough, it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount." My manual didn't have very good info about lubricating the brew group, so I referred to some Youtube videos demonstrating the methods. A sourced a 3rd party food safe lubricant from Amazon which I applied with Q-tips, but in retrospect they also sell Saeco "maintenance kits" which would have been cheaper & easier to apply, plus it includes a new O-ring.
Jun 01, 2014 | Saeco Odea-Giro Espresso Machine
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
I have a new Saeco Odea Giro Coffee Machine and have turned it on for the first time. I followed the instructions but the red alarm light is flashing and no "steady flow of water comes out of the wand". I...
Feb 15, 2010 | Saeco Odea Giro Plus Coffee Maker
Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Dec 10, 2009 | Saeco Talea Giro Espresso Machine
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Feb 23, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odeo Giro Automatic Espresso Cappuccino Maker Built In Grinder Logo
47 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
