Question about Hankscraft Gerber Model 240 Cool Mist Vaporizer Humidifier Air Moisturizer Euc
What is proper procedure for running vinegar through my Hankscraft cool mist humidified?
Nothing has been tried. This is a 1960s model unit for which I no longer have an instruction booki.
  • 3 Answers
Not sure why you would want to. Vinegar is typically used to remove calcium scale that remains after a heating element or electrodes boil off water. The Hankscraft 240 doesn't boil the water off. All the minerals in the water go out the spout with the mist.
Posted on Apr 22, 2015
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
A white dust is comming from my cool mist humidifier, is is dangerous to breathe?
Its probably just from the minerals in your water. If so you should be fine although it does make a bit of a mess around the house. If the white dust bothers you, fill your Hankscraft 240 with distillers water rather than tap water and the problem will go away.
Mar 07, 2015 | Hankscraft Gerber Model 240 Cool Mist...
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Crane humidifier stopped working
My crane cool mist stopped misting. I always use filter water. Cleaned it with vinegar. What's can I do?
Mar 02, 2013 | Crane Penguin 1 Gallon Humidifier
How to clean sunbeam humidifier swm5250
CLEANING AND MAINTENANCE INSTRUCTIONS (from the manual):
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
Jan 22, 2012 | Sunbeam Humidifiers
HOw do I clean the cool mist humidifier?
If there is a lot of scale and mineral deposits , you can run a 50/50 solution of White Vinegar and water thru it, by half filling the tank with the solution. When it's almost empty, turn it off, empty the remainder of the solution and flush the system with clear water. In the future I recommend that your use bottled Distilled Water, instead of tap water.
Feb 17, 2011 | Walgreens Cool Mist Humidifier Humidifier
How do I clean / sanitize my sunbeam humidifier swm5250 with bleach?
I'm no expert, but a friend of mine loaned me her humidifier recently and she just put some bleach and water in the tank and cleaned the tank with that. It did leave a smell of bleach in the tank that could be smelled any time it ran, but after a few refillings, it went away, and I figure if it smells there must be a little left, which means it should clean the working parts fairly well too. (while you're running it the first few times) And the medicine tray in the SWM5250 is dishwasher safe, so I would just run that through the dishwasher, but bleach should be fine for that too.
Jan 27, 2011 | Sunbeam Humidifiers
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Dec 19, 2009 | Sunbeam Health at Home Warm Mist...
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
Hankscraft Gerber Model 240 Cool Mist Vaporizer Humidifier Air Moisturizer Euc Logo
394 people viewed this question
Top Hankscraft Humidifiers Experts
Mack Baxter
Dennis
Are you a Hankscraft Humidifier Expert? Answer questions, earn points and help others
