Question about Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer
Possible to replace lost switch on Aquarius WD645A PCB
My daughter has manage to pust the on/ off / start switch buttons through into the machine and break off one of the samll 1/4" (1/2 cm) soldered-on push button switches! Is is possible to buy these any where as individual items please? Thanks
  • Mel p
    Mel p Dec 12, 2014
    I mean "push" not pust! Can't see an edit button?
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
I have somehow managed to put my hotpoint aquarius into test mode
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi i have a wf321 aquarius. When i switch it on
looks like the main pcb is failing you.. checke all connections to be on the safe side( with the power off & plug out of course).
Thanks
Dec 18, 2009 | Hotpoint Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Hotpoint washing machine Aquarius WD640
Try this sequence; Hold down start and cancel button together, TEST should disappear of display,
Then hold down START/ CANCEL, and ON/OFF at the same time.
The message D/off should appear in the display, it should then work.
If it does not then the main pcb is likely to be faulty..
That will mean calling an engineer.
Pleas rate my fixya solution.
Thankyou.
Feb 07, 2009 | Hotpoint Aquarius WD63 Front Load...
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Aug 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer Logo
49 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
