Question about AMA CPT Code Books; Standard, Softbound, 2013
The impantation of a patient activated cardiac event recorder cpt code?
Can you go through a metal detector with a pacemaker?
Metal detector security screening appears safe for people with pacemakers or implantable cardioverter-defibrillators (ICDs), researchers found. Metal detector gates, which generate much stronger electromagnetic fields, also appeared safe for cardiac rhythm device patients in a prior study by the same research group.
Apr 22, 2018 | Retail Supplies
Placement of electrodes in a 5 piece system, please
Contact the manufacturer. This equipment is specialized and subject to patent restrictions on that info.
May 26, 2015 | Cardiac Science Burdick Vision 5L Digital...
NEED C CODE OR DEVICE CODE FOR CPT 37224
http://www.ncdhhs.gov/dma/bulletin/0111bulletin.htm#cpt
Oct 15, 2014 | Office Equipment & Supplies
What is Automated external defibrillator?
Wikipedia says: An automated external defibrillator (AED) is a portable electronic device that automatically diagnoses the potentially life threatening cardiac arrhythmias of ventricular fibrillation and ventricular tachycardia in a patient,[1] and is able to treat them through defibrillation, the application of electrical therapy which stops the arrhythmia, allowing the heart to reestablish an effective rhythm.
With simple audio and visual commands, AEDs are designed to be simple to use for the layman, and the use of AEDs is taught in many first aid, first responder, and basic life support (BLS) level cardiopulmonary resuscitation (CPR) classes.[2]
Apr 22, 2013 | Medical
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
How do you activate the silent mode?
There isn't a silent mode. According to National Patient Safety Goals created by the Joint Commission, a vital signs monitor should NEVER have a mute mode because a caregiver might miss an important event. Sorry.
May 20, 2010 | General Electric Dinamap ProCare Series...
Cardiac Science AED G3 has serice light on yet all
depending on the manufacture date it is most likely in need of the 2005 AHA software upgrade. You might be able to get it for free from Cardiac Science or you might have to send it to a service company. We can do it. 8009894909. Call Cardiac science first and give them your serial number.
Oct 15, 2009 | RTO Cardiac Science Inc Powerheart Aed G3...
AMA CPT Code Books; Standard, Softbound, 2013 Logo
509 people viewed this question
Top AMA Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you an AMA Work Safety Expert? Answer questions, earn points and help others
