Question about Bama 1997 Ford Mustang V6 38007 SCT LiveWire Tuner w/ 3 Free Custom Tu
I change spark plug. the rmp go down to one . it stalls out. not it will not start at all. it makes kracking sound. I know when I put oil in lid on it had tilted n oil went all over . now has oil in i
What can I do fix it
    Problem Solver:
  • 12 Answers
DID YOU CHECK THE COIL? ALSO RUN A COMPRESSION CHECK ON EACH CYLINDER. YOU CAN GET A COMPRESSION CHECK GAUGE AT ANY AUTO PARTS STORE. SOME STORE WILL LOAN TOOLS.
Posted on Dec 12, 2014
  • Christina Hitchen
    Christina Hitchen Dec 12, 2014
    no i did dont know which one.not it will not kick over
Put new gas and new oil in and tried to start. Would stall in few seconds when could start. There is fluid dripping from the filter area
Hi Anonymouse:
I'd be checking to make sure that the correct fluid in the correct amount was added to the correct place.
Start with the oil. Check the dipstick or indicator level. Too much oil will stop the engine. Sometimes gas get accidently put in the oil filler if an inexperienced person is helping with the maintenance.
Gas.......... Make sure that oil was not accidently added to the gas tank. Drain the carb and put fresh gas in the gas tank.
Spark plug.;.... pull and check for fouling. Replace if not really clean. Check for hot blue spark before re-installing.
This should get you back digging up the garden very soon.
May 15, 2015 | Garden
I have a 2000 Saturn SL2 that was sitting for a about 2 years. So far we have replaced the engine computer, ignition coil and spark plugs. The engine is still running rough, it ramps up and down on it's...
Change the gas (and the oil, with Synthetic). The gas loses it's volatility after just a few months and starts to go bad. Siphon all the gas out and put in a fresh tank. Let us know if that helps.
Aug 07, 2013 | Saturn SL2 Cars & Trucks
My gilera keeps needing a new spark plug
1st: Are u sure you're using the right spark? There are short and longer sparks, so check it;
2nd: Check if you're using a good oil, since sounds there are excess of oil on cylinder. Maybe changing the autolube oil could help.
Mar 22, 2013 | Motorcycles
Polaris 500, starts fine but when you give it gas is stalls
check the exhaust lobe on the cam. these are prone to wear if oil changes are neglected. try to run it with the airbox lid removed and see if there is any change.
Feb 16, 2010 | Polaris ATV
Truck stalled wont start again 2003ford 6 liter diesel
check spark plugs/wires alternator could be shot see if battery is dead
Nov 03, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
94 Buick Park Avenue that stutters under a light load
check for a loose harmonic balancer(big pulley on bottom of engine.
oil soak can damage this part too.
Aug 06, 2009 | 1994 Buick Park Avenue
Will start up run for awhile then stall and wont restart
Hello, I would start with a general tune up. Spark plugs and wires, Fuel Filter, Oil Change and Filter Change, Air Filter Change, Some injector cleaner would not hurt eirther. Be sure to lubricate your high mileage car and also use a farily good oil for your motor as well. The run for awhile problem sounds like bad spark plugs. I would change your spark plugs, wires, distributor cap, and rotarty button.
May 20, 2009 | 1993 Honda Accord
Car won't Idle
do a compression test,if that checks out,oil gets in spark plug wells and sometimes not running on all 4 plugs pull spark plug boots and use paper towels twisted up and clean out oil around plugs and clean the end of the boots,
Mar 31, 2009 | 1996 Plymouth Breeze
1992 honda accord lx starts okay then idles down wants to stall
a good tune up shall solve your problem. replace the ff: spark plug. spark plug wires, air filter, fuel filter, and an oil change, good luck!
Dec 21, 2008 | 1992 Honda Accord
Bama 1997 Ford Mustang V6 38007 SCT LiveWire Tuner w/ 3 Free Custom Tu Logo
Top Bama Computers & Internet Experts
David Payne
David Payne
Are you a Bama Computer and Internet Expert? Answer questions, earn points and help others
