Question about GE Lands Phones
I have a GE model #27909EE1 phone. The phone rings & the answering machine works, however, people cannot hear me when I talk into the phone.
I unplugged the phone & plugged it back in again
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
SOURCE: Answering machine
HI,
I have a vtech 900 mhz, i purchased from the goodwill and everything works exept i have the other personsgreeting on the phone when someone calls my home. I need help on how to change the greeting so it will be my voice and not the other persons that owned it. could someone please help
Thank you
Sweetypie62
Posted on May 03, 2008
Kurth
  • 86 Answers
SOURCE: GE 6.0 27909EE1 cordless phone
Turn the power off for like 10 minutes and then turn it back on. Make sure its not on fax mode, but tel/answer mode
Posted on Aug 17, 2008
SOURCE: model 28112ee2-4 dect 6.0
SOLUTION: My handsets stopped ringing after power was stopped to the main base, too. I put one on the main base and that one started working but the others still didn't work. So I put the other phones on the main base while I called from my cell and let it ring. The other phones started to ring and work again.
Posted on Oct 18, 2008
SOURCE: Our ringer on our cordless won't ring.
hit the # button
Posted on Apr 17, 2009
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
Need instructions to (finally) use the answering machine portion of a ge 27909ee1 cordless phone. Cannot find manual.
You can download the complete instruction manual in PDF format by clicking this link:
http://www.home-electronics.net/ge/pc/IB/27909EE1_IB.pdf
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 07, 2010 | Uniden Cordless Phone
Model# 27909EE1-A the automatic answering system is not working
Here you are...
Recording the Outgoing Announcement
For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible.
1. Make sure the answering system is ON.
2. Press and hold the announce button on the base until the speaker announces "RECORD ANNOUNCEMENT AFTER TONE".
3. Begin speaking after you hear the beep.
4. Release the announce button when you finish your announcement.
NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing.
NOTE: The maximum duration allowed for outgoing message is 2 minutes.
Also, here's a link for your manual..
http://www.smithgear.com/ge-27909ee1.html
If this helps, plz rate this 'fixya'. Thank you kindly.
Feb 12, 2009 | Uniden Cordless Phone
I have a GE 27909EE1 Dect 6.0 phone and cannot find the manual. I need instructions in order to program it.
Here's a link to the manual for the GE 27909EE1 Dect 6.0 phone on the manufacturer's website. You can download it free and print it if you wish.
Dec 02, 2008 | Lands Phones
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
Aug 17, 2008 | Uniden Cordless Phone
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Cannot hear person calling
I am having the same problem with the same model phone! The line works with another phone but not with the GE cordless. If I call someone with the GE cordless they can hear it ring and hear me talking but I cannot hear them speaking. Silver Spring MD
Sep 06, 2007 | GE 21028GE3 Cordless Phone
Lands Phones Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
