Question about Sewing Machines
How replace a needle threader - Sewing Machines
  • 778 Answers
Hello, What is the make and model for the machine that you are replacing the needle threader. WIll have to have that in order to download a manual.
Posted on Dec 12, 2014
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
I need an automatic needle threader for a Brother NS30 Le
Fixya does not sell replacement needle threaders.
Aug 05, 2016 | Brother Sewing Machines
The needle threader is not lining up with the needle. how do I lower the needle threader?
You don't need to adjust the needle threader. You need to adjust the height of the needle so it meets the needle threader. Just hand rotate the hand wheel (always toward you, never backward!) until the needle is at the correct height for the threader.
Apr 21, 2016 | Sewing Machines
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
Needle threader doesnt work
it would probably be better to take the machine to a sewing machine
shop & have it done.
my needle threader is attached to the needle threader bar inside the machine & I imagine your is too.
Apr 26, 2012 | Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Janome 1860 needle threader
If the hook is bent, you might be able to straighten it, but I would go to my dealer and purchase a new threader. It is much easier to replace it.
Feb 06, 2012 | Janome Sewing Machines
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
How do you use a needle threader for a plus 1 viking sewing machine
If it's the viking needle threader that was made for this machine, you would mount the needle threader over the needle screw. The part that fits over the needle screw of the needle threader is an eccentric. You rotate it until the hook of the needle threader slips into the eye of the needle. Once that happens you mearly put the thread in front of the threader hook and pivot the needle threader back out of the needle.
Apr 26, 2011 | Husqvarna Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
