Question about Kitchen Appliances - Others
Ice machine stay on harvest after freeze cycle
The bin light stay on
    Master:
  • 571 Answers
Check the water solenoid to make sure it is not stuck & slowing water through it all the time.
Posted on Dec 13, 2014
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigeration code on scotsman ice machine model cme506as-32f.What could be the cause?
Unit is off& Refrigeration diagnostic light is on or blinking. Possible Cause,( Low discharge or long freeze cycle. Probable correction, if the Refrigeration light is glowing steadily there is a probable refrigeration problem.) 2. Possible cause. Harvest problem. Probable Correction. If refrigeration light blinks once and repeats, Look for a harvest Problem.**On Controllers 17-1 and higher, This also indicates that cubes were (sensed) by the bin controls. 3. Possible Cause. Hot gas valve failure, Probable Correction. Check hot gas valve operation. 4. Possible Cause, High Discharge Temp. Probable Correction, If the refrigeration diagnostic light blinks 3 times and then repeats, check for a reason for high discharge temperatures. 5. possible Cause, Harvest problem. Probable Correction, Controllers 17-1 and higher, if the light blinks 2 times and repeats, check for a harvest error- no cubes sensed. 6. Possible Cause, Unit dose not go into harvest - exceeds maximum freeze time. Probable Correction, Push and release off button. Push and release Freeze button. Check operation. next Push cube size float down and check operation. 7. Possible Cause, Exceeds maxi harvest time. Probable Correction, Check for cause of long harvest cycle. Try not to put any gauges on system until you have to. Every time you do you loose refrigerant out of the system.
May 02, 2014 | Kitchen Appliances - Others
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
It will not stay in harvest cycle long enough to make ice before it goes into defrost
First it has to go through freeze cycle then harvest cycle to drop ice then back to freeze cycle. If you have never worked on ice machines before you should call a service company.
Aug 16, 2013 | Manitowoc QY-0214A Self Contained Ice...
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Jan 16, 2009 | Hoshizaki KM-1600S Stackable Crescent...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
