Question about Konica Minolta Office Equipment & Supplies
Is there a fusser reset for the c3350
Open and close front door, turned off/on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Call the nearest Minolta repair facility
Posted on Dec 14, 2014
How can i cycle power
Dear
It might be thermostat open, pl. open the fusser assembly check the thermostat for continuity one or two bottom like thing having two wings. if its open detach this and knock hardly with hand and ay hard surface it may reset to show continuity. put the thermostat in it position and check.
Also it may happen the fusser melts, If the fusser roller and pressure roller attached each other then you have to replace both fusser and SMPS. If you are not sure as it was connected to DG set power.
Thanks.
Feb 18, 2015 | Samsung ML-1640 Monochrome Laser Printer
How do I fix this paper jam2
Dear
Open and close the front door. The jammed paper
automatically exits the machine.or gently pull the paper out of the output tray.
If there is any resistance and the paper does not
move when you pull, or if you cannot see the paper
in the output tray, open the rear door by pulling the
tab on it.Remove the jammed paper by gently pulling it
straight out.Close the rear door.
Some times it may happen if machine gets ready and after one page print it shows jam2 , then check the lever for jam2 sensor on the top of fusser, the spring may dislocated or lever may broken(rare).
Thanks.
Feb 13, 2015 | Office Equipment & Supplies
How do i reset error code 3922 konica minolta c3350
Check 1st the following : Fusing unit • Fusing temperature sensor/2 (TEM2) • DC power supply (DCPS) • Printer control board (PRCB). If everything ok then RESET thru [Utility]
Dec 12, 2014 | Konica Minolta Office Equipment & Supplies
How do I reset trouble code 3922 fusser
Turn Off main Sw. while pressing [Utility] turn On main Sw. for 5secs. The TROUBLE RESET will appear on display press it and it will say OK. If you do not have defective parts in fuser.
Dec 12, 2014 | Konica Minolta bizhub Office Equipment &...
Samsung 4321ns u1-2320 error reset
Dear
The error is open heat error. this may caused due to the opening of thermostat. either fusser assy replaced or thermostat may be replaced. In case of melt replace both smps and fusser assy.
Thanks.
Oct 05, 2014 | Samsung Office Equipment & Supplies
Konica minolta bizhub c253,how to reset transferbelt by using fusser
There are two ways to reset an error code:
  • 1. Open the front cover, wait for a few seconds and then close it. If the error is still there try the second method.
  • 2. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code.
Aug 21, 2014 | Office Equipment & Supplies
What is errer #u1 2320
Dear Its related to fusser temp. Check the fusser assy. thermostat it may open . either it may reset or replaced with new one. The error code mean-OPEN HEAT ERROR.
thanks
Jul 19, 2014 | Samsung SCX-4321 All-In-One Laser Printer
C-5102 Open and close the front door to reset however alarm still up
Open the front door and pull out all four image units not the toners. once out separately shake each image unit along its axis you want to have the developer and toner inside each image units to be evenly spread along the axis of the image units so that the motor that turn the drum and developer are not forced to turn with all the developer sitting at one end, hopefully the main motor is not burned out or worse case the main board is shot. Store all image units and toner horizontal not vertical..open close front door Might also have to replace the four image units if the hard to fig which drum might not be turning. Open close front to reset after all of this
Apr 11, 2014 | Konica Minolta bizhub C250 All-In-One...
Service code sc520
Paper tray error.Try reset by open/close the front door,if not reseting enter in the service mode :press mode(yellow)key-107-Clear/Stop(red)key (keep pressed more 3 seconds) enter in SP mode,open the front door and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 27, 2013 | Ricoh MPC3500
Hi this is hari, am using samsung scx4300 printer and i installed drivers.but am getting a error in display like "Open heat error", Please could some one help me for smme. Thanks,
Dear
The open heat error due to the temp. of fusser has not attained within predefined time due to either failure of heater lamp(rare),failure of thermostat(frequent),failure of fusser assembly(melt).
In first two case the parts can replaced(may be reset thermostat by knocking on hard surface) but incase of fuser melts then both fusser assy. and smps to be replaced confirm whether the printer power from DG set.
Thanks.
Jan 16, 2011 | Samsung SCX-4300 Monochrome Laser...
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
