Question about Konica Minolta Office Equipment & Supplies
How do i reset error code 3922 konica minolta c3350
Open and close front door, turn off and on
    Habit-Forming:
    New Friend:
  • 106 Answers
Check 1st the following : Fusing unit • Fusing temperature sensor/2 (TEM2) • DC power supply (DCPS) • Printer control board (PRCB). If everything ok then RESET thru [Utility]
Posted on Jan 07, 2015
Nitrotrike
  • 589 Answers
SOURCE: KONICA MINOLTA CF2001 ERROR C0096
C0096 is an error with the transfer belt.
Posted on Jan 15, 2008
  • 4 Answers
SOURCE: Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Posted on Apr 08, 2009
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
Kevin Hayes
  • 167 Answers
SOURCE: error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
Posted on Jan 06, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
My konica minolta printer is show error code 4501
sir, Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
Mar 13, 2017 | Konica Minolta Office Equipment & Supplies
How do I reset trouble code 3922 fusser
Turn Off main Sw. while pressing [Utility] turn On main Sw. for 5secs. The TROUBLE RESET will appear on display press it and it will say OK. If you do not have defective parts in fuser.
Dec 12, 2014 | Konica Minolta bizhub Office Equipment &...
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Error c0520
open and close the front door and see if the code resets
Nov 01, 2013 | Konica Minolta Office Equipment & Supplies
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code 2152
Jan 02, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
805 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
