Question about Lands Phones
User mannual for talktalk 3022 ultra slim dectphone
Brought a used kindle dx and didn't get a manual don't know how to use or what buttons to push
See here: Amazon Kindle DX Support
Once you have the machine running to read anything, the Kindle user manual is a pre-installed eBook on the device and also available for free via the Kindle storefront in case the previous owner deleted it.
Dec 19, 2010 | Amazon Kindle DX
I have a 3022 13929991 Ken Elite Dishwasher - I need to know where i can pull up a mannual got this at Sears Outlet Control lock is on and i can't get it off thanks for your help
Normally you should press the child lock for about 6 secs to turn it off. But if there is a fault in dishwasher then child lock light will be on or flashing.
This means some diagnostics is required to find the cause of the fault.
However, I don't think you have provided the correct model number of your kenmore elite dishwasher.
Normally it should be 665.xxxx Please check the model number carefully and post a comment.
Nov 26, 2010 | Kenmore Dishwashers
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
How do you fit sim in ultra 2
The sim card appears to be inserted into a slot next to the memory card. You will have to remove the battery cover and battery to do so.
Your manual can be downloaded from: http://downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CttFileID=2197628&CDSite=SFC_UK&SiteType=02&VPath=UM/200903/20090314115948968/Samsung_S8300_UM_Open_Eng_Rev.1.2_090213.pdf
Aug 25, 2009 | Samsung Tocco Ultra Cell Phone
go to the website of the manufacturer. You usually can find the users guide there.
Oct 13, 2008 | Janome Sewing Machines
VE920 on powerup will not detect a cable signal stuck in air mode
In your menu from your remote you should be able to find a search mode that you can manually select. at that point you should be able to select source and start a search.
Mar 08, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
