Question about 2011-2012 Sierra 1500 Pickup 18" 5498
How to install wiper blade
Trying to change out damaged blades
    Problem Solver:
  • 15 Answers
Not being a smart ... but go to Advance, Autozone, O'Reilly and they will install them free
Posted on Nov 16, 2017
  • 156 Answers
Usually the edge of the blade just needs scrubbed with a kitchen scrubber to get them working well again. If that doesn't work, then the people at an auto parts store like Auto-Zone will help you change it. You'll have to buy them from an auto parts store to get help. Wal-Mart won't help you.
Posted on Dec 12, 2014
How to change wiper blades
Here is our install step-by-step guide for a 2003 Lexus ES300
Great Wipers, Great Prices, Step-by-step instructions with Free Shipping. https://www.wiperbladesusa.com/lexus/es300/2003/how-to-change-wiper-blades
Sep 13, 2011 | 2003 Lexus ES 300
My rear wiper gets snagged on the fixture of the cyclopse brake light. My 2005 Dodge Magnum was rear-ended awhile ago (and repaired), and then shortly threafter I had the Valvoline-Quicky-Oil-Change Team...
First try measuring the length of the wiper blade and calling your dealer or auto parts store to verify that the length is truly correct. Technicians might have grabbed the wrong length. If that's ok, go back to the people who repaired the accident damage and ask them if the arm was correctly installed, sometimes one notch on the shaft of the the blade arm will make the difference in wiper blade travel, if both of these possibilities fail, then maybe the shaft might be bent, or loose. Hope this helps-Jim
May 13, 2011 | 2005 Dodge Magnum
How do you change the wiper blades on an 2005 acura TL?
TO CHANGE WIPER BLADES ALL YOU DO PRESS ON THE TAB AND PUSH THE BLADE ASSEMBLY OUT OF THE HOOK END TO REMOVE IT.IF YOU HAVE DIFFICULT TIME REMOVING WIPER BLADES.THE AUTO PARTS STORE SALES PERSON WHERE YOU PURCHASE BLADES WILL INSTALL THEM FREE FOR YOU.
Dec 16, 2010 | 2003 Acura 3.2TL
How do I change wiper blades on a Ford 500
This is a fairly simple job.
#1 Pull the wiper arm away from the vehicle.
#2 Turn the blade 90 degrees so that the blade and the arm make a 'capital T' shape.
#3 Pull the blade straight off of the arm.
#4 Install the new wiper blade so that it forms a ' T ' with the arm.
#5 Turn the blade back to the normal position in line with the arm.
#6 Ease the wiper arm and blade back against the windshield.
#7 You are done. Good luck
Jan 03, 2010 | 2006 Ford Five Hundred
How to change the rubber on wiper blade of 06 corolla
My advice is to forget changing the rubber. Just buy a complete wiper blade minus the arm. This way although you will spend a little more but avoid the hassle and get an entirely new blade. If you buy a quality blade you will only need to replace it once a year or every other year if the car is kept in a garage. I have been using the Rain X Latitude wiper blade and have found it to be a fantastic blade. After 1 year of use it is as good as the day it was installed. Most blades especially rubber blades start to deteriorate after 6 months. Whatever you buy make sure it is made of silicone and not rubber.
Dec 10, 2009 | 2006 Toyota Corolla
I cant figure out how to change my windshield wiper blades on 2001 ford ranger
How to Replace Wiper Blades Guide (Typical):
Potential tools needed to replace wiper blades:
  • Flat blade screwdriver (small)
  • Small nosed pliers
  • Latex or vinyl gloves
  • Safety goggles
To replace wiper blades theactual action of replacing the blade is no big deal, it's the locationof the blade down below the hood that can make it difficult though.Sometimes it helps to open the hood to gain access to the wiper blades.Other times it is helpful if the wiper blade is somewhere in the motionline of wiper action. The trick is to get the wiper to stop somewherein the wiper arc. Turn the wipers to the on position and allow thewipers to start, and then shut the key off when the wiper has arrivedin a desirable position on the windshield. To replace your wiper bladesplease follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wiperson, when the wipers are in the middle of their arc turn the key to theoff position. (Note: if this can't be done because of wiper conditionand you want to avoid scratching the windshield please open your hoodto gain access)
  • Step 2: Locate the mounting clips at the top pivot on the wiper blade
  • Step 3: Release the clip and remove the wiper arm
  • Step 4: Match the size of the old blade against the new blade to ensure proper fit and operation
  • Step 5: Reinstall the new wiper blade and recheck wiper operation
Common Problems:
  • Make sure the wiper blades are the same size as the original blades.
  • When replacing wiper blades not getting the blade onthe mounting pin completely allowing the wiper arm to become dislodgedand possibly causing damage to the windshield.
  • Using wiper blades after the blade has failed permanently damaging the windshield by craving scratches in the wiper arc.
  • Wiper blade can create a chattering noise when theblade is not properly balanced allowing the blade to "flop" back andforth as the wiper direction changes.
I hope help you with this (remember rated this help) Good luck.
Sep 16, 2009 | 2001 Ford Ranger Regular Cab
How do I remove front wiper blades to replace with new ones on my 2006 nissan quest
How to Replace Wiper Blades Guide:
  • Safety goggles
To replace wiper blades the actual action of replacing the blade is no big deal, it's the location of the blade down below the hood that can make it difficult though. Sometimes it helps to open the hood to gain access to the wiper blades. Other times it is helpful if the wiper blade is somewhere in the motion line of wiper action. The trick is to get the wiper to stop somewhere in the wiper arc. Turn the wipers to the on position and allow the wipers to start, and then shut the key off when the wiper has arrived in a desirable position on the windshield. To replace your wiper blades please follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wipers on, when the wipers are in the middle of their arc turn the key to the off position. (Note: if this can't be done because of wiper condition and you want to avoid scratching the windshield please open your hood to gain access)
Common Problems:
  • When replacing wiper blades not getting the blade on the mounting pin completely allowing the wiper arm to become dislodged and possibly causing damage to the windshield.
  • Wiper blade can create a chattering noise when the blade is not properly balanced allowing the blade to "flop" back and forth as the wiper direction changes.
Sep 14, 2009 | 2006 Nissan Quest
How to replace the wiper insert at the back of
  1. REMOVE RR WIPER BLADE
    1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
    2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
  1. REMOVE REAR WIPER RUBBER
    1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
  1. INSTALL REAR WIPER RUBBER
    1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
Sep 12, 2009 | 2005 Toyota Matrix
Change wiper blades
you are changing the blade not the arm oem connector dont need to be touch
Jul 01, 2009 | 2006 Jaguar XJ8
How to remove and replace the wiper blades on a 2006 BMW 325i.
My suggestion....go to Schuck's/Kragen?Chief's?Auto Zone....they will install them for FREE.
Mar 11, 2009 | BMW 325 Cars & Trucks
2011-2012 Sierra 1500 Pickup 18" 5498 Logo
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
