Question about Video Game Consoles & Games
How to fix a excalibur grandmaster chess computer that has error message ERH8. The computer does not do anything but beep.
I have tried centering the pieces and have pressed all clear. I have also replaced batteries. Have never been able to play a game on this computer - just keeps showing error message ERH8 and beeping when pressing buttons.
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
top50
  • 134 Answers
SOURCE: Directional Button and L Button Problem and another problem.
I think there might be a problem with your configuration, remove all plugin then try to restore to default setting on setting menu. and/or if your psp installed Custom firmware, the umd speed are set to fast. do this via recovery menu (hold R trigger while turn on psp). you may need to fix L button if it is stuck. you may consoder sending it back to Sony for repair.You can call SONY support at 1-800-345-7669. hope this helps.
Posted on Nov 07, 2007
SOURCE: my psp keeps on asking me if i want to quit the game
maybe you keep pressing the home button
Posted on Oct 20, 2008
SOURCE: Humidity buttons don't seem to work.
the control board is a very simple design and it is to signal and switch options like fan speed, power on/off, humidity up/down and sets the on/off run time. Like above the board does collect dust,but the true problem runs deeper.
My unit was stuck in run mode with the fan speed, humidity and run timmer non functioning. the unit worked and the power switch turned it on and off. The display said ON
I removed the front cover (two screws) and slight pressure on the side of the cover to remove it. This exposes the control board. The control board can be removed by removing the 6 screws on the board. the cable can then be removed by pulling out the multi-pin ribbon cable.
I diagnosed that only two of the 5 push button switched were functioning. There was also dust and mold on the board. This board is poorly protected from the moist air entering the unit and the constand moisture causes corrosion on the board, the switched seem to be the weak link.
By using a multi meter I noted that only the power switch and the humidity down button were making contact when pressed. Now it all came together. I could turn it on and off. and if you press the humidity down button to the lowers setting (ON) means run all the time.
I used a elecronic contact cleaner and sprayed it into each of the switches. I wiggled it around and blew it out with canned air. It took a few wiggles and blasts but all switched then made contact. I the board back on and tested all functions and it was like new. The contact cleaner should keep it protected for a while. The non functioning of the switches works both ways. They can stick on also. This would explain most of the other control problems. These switched are common and can be picked up at Radio Shack. On a do-it-yourself bananna scale it was a 2 for me, but I had the tools and the spray. I am not sure what sears gets for the PC control board,but this is the issue and if they were to address this the unit complaints would drop greatly.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Wii VC games won't play on hdtv
I had the same Black Screen problem and I finally have a fix for it!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Posted on Feb 19, 2009
Why do my chess piece move oddly
It must a rough side or edge just try to smoothen the base of your chess piece...
sand paper is good
Jun 18, 2016 | Excalibur Phantom Force Electronic Chess...
QU159 Instruction Manual
Hi
You can get your manual here:-
http://www.manualslib.com/download/50261/Excalibur-Lcd-Chess.html.
Hope it solves your problem.Please rate me if my solution helped you.
Regards,
bonefirediv.
Apr 12, 2014 | Traditional Excalibur Lcd Chess & Checkers...
Fritz chess grandmaster challenge won't install to win8
Many old games not running on Windows 8 or 8.1 due to compatibility issues. Check if there is a latest version is available otherwise you'll not be able to play the game.
Mar 22, 2014 | Viva Media Fritz Chess - Grandmaster...
Fritz chess grandmaster challenger 3 does not install on to win8.1
What does it say?
Possibly it might work if you install VirtualBox with some old windows first:
Solution
Model E714. Where can I get a manual?
If you haven't already, try Googling (Excalibur)(E714)(manual) without parens, of course.
Jan 10, 2013 | Excalibur Electronics Einstein Chess...
I need to get the manual model 740D phantom force
I had to find it too!
http://www.excaliburelectronics.com/images-manuals/Phantom%20Force%20Electronic%20Chess%20740D.pdf
Oct 30, 2009 | Excalibur Phantom Force Electronic Chess...
Sound on Excalibur LCD chess travel game
The manual can be found here :)
http://fitness.manualsonline.com/manuals/mfg/excalibur_electronics_inc/lcd_chess.html
May 13, 2009 | Traditional Excalibur Lcd Chess & Checkers...
Error Message MT01R
Fiddle around with the mechanism lock on the bottom. Once it engages properly, it will work. I had exactly the same problem.
Dec 27, 2008 | Excalibur Phantom Force Electronic Chess...
Video Game Consoles & Games Logo
107 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
